A little Ignition help please #525522 11/13/04 04:45 PM
Ganoid Offline OP
I purchased a used Jacobs Ignition for my 3.0 this last week. I didnt get the secondary trigger that was supposed to be in the box so I thought I would try and get things hooked up with out it.
At this point everything works except my tach, it gets a little crazy when I get abve 2k RPM's. I think the problem lies in tapping into the wires between the igniter and the coil and some how I have changed the load. I thought I could run with the factory coil unplugged but it wont fire unless I have the factory coil plugged in to keep a load on the igniter. My temp solution was to just ground the coil lead and leave it plugged in.
Has any one had this problem before?
Do you think putting a fixed or variable resistor in place of the coil would work? allowing me to change the load on the igniter and keep from having my OE coil fire all the time.
I guess Im just fishing for advice here <img src="/forums/images/graemlins/smile.gif" alt="" />
90 Xcab V6
3.0 Rebuilt/Balanced
P/P w/OS valves
Downey Hdrs,Jacobs Ign
5.29's,Tru Trac+Lockright
4"TG SAS+Rear Kit on 35's
(DOA Racing = $1200 lesson <img src="/forums/images/graemlins/angry.gif" alt="" />)
www.performancecylinderheads.com
Re: A little Ignition help please [Re: Ganoid] #525523 11/13/04 11:04 PM
Snowtoy Offline
What system did you get?, is it for a Toyota? The one that I have, and the ones have helped install, plug into the ignitor w/2 wires, and completely bi-pass the stock coil, using the Jacob's coil instead. You may want to give <a href="www.jacobselectronics.com/" target="_blank">Jacob's Electronics</a> (now owned by Mr. Gasket) a call, and talk to a tech. You probably need to get the secondary trigger for everything to run right.
Re: A little Ignition help please [Re: Ganoid] #525524 11/15/04 06:16 AM
JWHnAtl Offline
I've got an extra secondary trigger (well as long as that's not what's wrong with my truck). PM me if you are interested.
'89 3.0 4Rnr: Jacob's Electronics, K&N, CF Dual Frict, 4:56 w/ Truetracs, 33 BFG AT/KOs, Cascade Audio, Pro-Comp 4" susp & 2" body (previous owner)
I know, a lot of wasted time and money ... if I knew then what I know now....
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5936 MB (Peak: 0.6474 MB) Data Comp: Off Server Time: 2026-06-04 15:36:12 UTC
