Re: Aftermarket reverse lights [Re: Scerb] #525682 11/16/04 02:42 AM
Snowtoy Offline
I would splice a trigger line from the wire at the tranny to a relay. The relay should be powered directly from the battery w/30 amp fuse. I would run a ground interrupt switch for the relay ground. This will allow you to turn them off when in town.
Or, you could mount them to the bumper, running a trigger from the back-up lights to a relay, and forget about an interrupt switch. Then mount another light on your roll bar for a utility light.
Re: Aftermarket reverse lights [Re: Scerb] #525683 11/17/04 03:40 AM
foxtrapper Offline
You can also simply put in a more intense bulb in the existing reverse light. That works quite well.
Re: Aftermarket reverse lights [Re: foxtrapper] #525684 11/17/04 03:48 AM
4Crawler Offline
I would still add a relay if upping the stock reverse light wattage. I burned out a reverse light switch on a VW when I stuck in a set of 55W halogen backup lights.
Re: Aftermarket reverse lights [Re: foxtrapper] #525685 11/17/04 06:52 AM
W
whitetoy Offline
This is what I did many years ago. Still going
strong. I guess the Toyota guys over-engineered
the backup light switch along with everything else. <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" />
Rick
1984 4Runner
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6080 MB (Peak: 0.6635 MB) Data Comp: Off Server Time: 2026-06-10 06:24:24 UTC
