Over torquing Problem... #525833 11/14/04 12:53 PM
A
allochris Offline OP
So ya, I snapped one of the 4 bolts from lower ball-joint to the steering knuckle. The rest of the bolt is of course stuck in the steering knuckle. What am I going to do?
Haynes manual says torque to 105ft/lbs, but that bolt snapped at 70ft/lbs...
The other 3s are still strongly torqued, can I get over this with only 3 bolts??? Damn Hanyes Manual... <img src="/forums/images/graemlins/barf.gif" alt="" /> <img src="/forums/images/graemlins/barf.gif" alt="" /> <img src="/forums/images/graemlins/angry.gif" alt="" /> <img src="/forums/images/graemlins/angry.gif" alt="" /> <img src="/forums/images/graemlins/frown.gif" alt="" /> <img src="/forums/images/graemlins/angry.gif" alt="" /> <img src="/forums/images/graemlins/evil.gif" alt="" />
91-22re(408xxxkm & counting with a rebuilt long block)- Flatbed/Camper
/33x10.5BFG-AT/Open 4:88/1.5"BJS/
+2"Shackles/Add-a-Leaf/AirLift/Dual-Batteries
Re: Over torquing Problem... [Re: allochris] #525834 11/14/04 05:12 PM
TexJeff87 Offline
You need a bolt removing tool...got 'em at Sears, looks like a weird backwards steep sided drill bit. You drill a pilot hole into the remnants of the bolt, screw this thing in, it bites, grabs the bolt, and it'll come right out. Since you have removed the head of the bolt it should come out pretty easy. If it doesn't come out right away, heat the area around the bolt, NOT the bolt itself.
And no, you shouln't drive around on 3. If it was OK to only have three then they would'a just put 3 on there. Know what I mean?
JT <img src="/forums/images/graemlins/patriot.gif" alt="" />
If Mad Max had a 4runner...
Re: Over torquing Problem... [Re: allochris] #525835 11/14/04 05:14 PM
Manson Offline
That torque sounds like for the ball joint castle nut.
Re: Over torquing Problem... [Re: allochris] #525836 11/14/04 11:21 PM
OOP'S Offline
While you are at it take a lug nut off each wheel, six are to many.JK <img src="/forums/images/graemlins/smile.gif" alt="" /> What size are the BJ bolts, about 8 mm? You are luckey that it got to 70 before it broke!!!
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
Re: Over torquing Problem... [Re: OOP'S] #525837 11/15/04 12:06 AM
mt_goat Offline
Yeah I think they are supposed to be about 30 ft-lbs for the 4 small nuts, the 105 ft-lbs is for the one big castle nut on the other end. I definely wouldn't run with only 3 of the studs for very long.
93 4X4 ext-cab, auto, SR5, 3.4 V6, supercharged, 2.1" pulley, URD fuel mods, Aquamist WI, IPT valve body mod, dual cases, 4" superlift, Alcan springs, 33 BFG MT, ARB locked front & rear, 5.29 US Gears, RB 1" BL, 1.5" BJ spacers, TJM T-17, Warn m8000.
Re: Over torquing Problem... [Re: mt_goat] #525838 11/15/04 12:09 AM
You might wanna replace all 4 cause they've been stretched so badly. Hate to see you get sideways. <img src="/forums/images/graemlins/ignore.gif" alt="" />
Re: Over torquing Problem... [Re: mt_goat] #525839 11/15/04 12:09 AM
willzrunna96 Offline
105ft lbs?????????? thats quite alot for an 8mm bolt man 105 is for the steering knuckle bolts. not those 4 ball joint bolts. i think the castle nuts are only 80 or 90
IF ITS ONE THING I LEARNED IS NEVER GO BY A "Haynes" manual i think if half the world listend to this guy "HAYNES" we;; all be in trouble www.alldatadiy.com
Re: Over torquing Problem... [Re: TexJeff87] #525840 11/15/04 12:15 AM
A
Thanks.
Does those really work even when the rest of the threads (no, it's not the castle nut bolt) left in the steering knuckle are tightly torqued to like 70lbs?
Is it like something similar to this? Like the ones in seen in the black case?http://www6.sears.ca/webapp/wcs/stores/servlet/ProductDisplay?storeId=10001&catalogId=10001&categoryId=10114&langId=-1&rrc=1&productId=157982710&pe=11
(btw, I had to use a 17mm socket for the 4 bolts, not too sure if they are 8mm bolts.)
Re: Over torquing Problem... [Re: allochris] #525841 11/15/04 12:22 AM
no they look like drill bits one is for drilling into the bolt one is for removing the bolt usally called easy-outs
Re: Over torquing Problem... [Re: willzrunna96] #525842 11/15/04 12:33 AM
A
Out of this page, which is best for me? (so many types!)
http://www.toolprice.com/category/screwextractors/
Thanks! <img src="/forums/images/graemlins/cheers.gif" alt="" />
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6398 MB (Peak: 0.7659 MB) Data Comp: Off Server Time: 2026-06-20 14:18:50 UTC
