TPS question on a 93 22re #526889 11/16/04 06:46 AM
4
4x4yotaman Offline OP
I have a 93 toyota truck with a 22re and i have been having some problems with it and i think it is the throttle position sensor. The only way i can accelerate is when i floor it otherwise no matter were i put the gas petal the truck has almost no power so i unplugged the throttle position sensor and got my power back but the truck is still not at 100% and i know that it is unacceptable to drive with the tps unplugged. I was wondering if anyone can tell me how to adjust the throttle position sensor or if they have had similar problems.
1985 4runner
Re: TPS question on a 93 22re [Re: 4x4yotaman] #526890 11/17/04 07:06 PM
seaflea Offline
Sounds like youre TPS has gone out. I had one go out once and had to limp home (idleing the whole way). There is a spring inside the TPS that has probably broken. You can try going to Roger Browns site and looking up how to adjust it if you hink is is still good.
www.4crawler.com
His site will tell you how to test one and how to adjust one. Good luck
Re: TPS question on a 93 22re [Re: seaflea] #526891 11/17/04 07:18 PM
4Crawler Offline
Re: TPS question on a 93 22re [Re: 4x4yotaman] #526892 11/18/04 07:05 AM
kewlynx Offline
Also, your FYI, I posted a link for an electronic manual about a couple months ago over in the Taco section if you need it.
**ubi apis- ibi salus**
Re: TPS question on a 93 22re [Re: 4Crawler] #526893 11/18/04 05:18 PM
4
Thanks for the link and the advise guys i did three of the five tests and my tps passed now i have to go buy some feeler guages to do the other two tests thanks again and ill let u know how it goes
1985 4runner
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6081 MB (Peak: 0.6725 MB) Data Comp: Off Server Time: 2026-06-07 10:07:15 UTC
