Re: Pulled these out of my Jamboree #526997 11/17/04 07:39 AM
get2now Offline OP
this is from a leaky (intake) valve seal. if it were black all around it would be from foobard rings.
So is this serious or something I can live with for a long time? What other problems will it cause?
Re: Pulled these out of my Jamboree [Re: get2now] #526998 11/17/04 08:01 AM
your head could probably use some work, but for now i bet its fine.
how much oil you burn?
Re: Pulled these out of my Jamboree #526999 11/17/04 10:32 PM
get2now Offline OP
It maybe uses 1 quart every 2,000 miles.
Re: Pulled these out of my Jamboree [Re: get2now] #527000 11/17/04 11:55 PM
do you leak any? burning that mutch is alright.. no bad not good.. i'd leave it on there until you have the means to deal with it.
Re: Pulled these out of my Jamboree #527001 11/18/04 08:28 PM
get2now Offline OP
It doesn't really leak any. It might have a little on the engine but it seems to be normal. It does run better now that I changed the plugs though. Number 6 is burning some oil but it's not really visable in the exhaust, but it was on the plug.
One of the reasons I asked if something could be wrong was because I thought it was under powered. I'd be lucky if I could get it up to 75 MPH on the freeway. To me that seems weak. <img src="/forums/images/graemlins/frown.gif" alt="" />
Re: Pulled these out of my Jamboree [Re: get2now] #527002 11/19/04 01:49 AM
the 258's get a little winded when running that fast... with how old the engine is and with it burning oil i'd say thats pretty normal.
usually you won't see oil coming out the tail pipe until you hit about 1 quart every 1000MI
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6101 MB (Peak: 0.6792 MB) Data Comp: Off Server Time: 2026-06-17 16:40:04 UTC
