Re: Pulled these out of my Jamboree
#526997
11/17/04 07:39 AM
this is from a leaky (intake) valve seal. if it were black all around it would be from foobard rings. So is this serious or something I can live with for a long time? What other problems will it cause?
[Re: get2now]
#526998
11/17/04 08:01 AM
your head could probably use some work, but for now i bet its fine.
how much oil you burn?
#526999
11/17/04 10:32 PM
your head could probably use some work, but for now i bet its fine. how much oil you burn? It maybe uses 1 quart every 2,000 miles.
[Re: get2now]
#527000
11/17/04 11:55 PM
do you leak any? burning that mutch is alright.. no bad not good.. i'd leave it on there until you have the means to deal with it.
#527001
11/18/04 08:28 PM
It doesn't really leak any. It might have a little on the engine but it seems to be normal. It does run better now that I changed the plugs though. Number 6 is burning some oil but it's not really visable in the exhaust, but it was on the plug. One of the reasons I asked if something could be wrong was because I thought it was under powered. I'd be lucky if I could get it up to 75 MPH on the freeway. To me that seems weak. <img src="/forums/images/graemlins/frown.gif" alt="" />
[Re: get2now]
#527002
11/19/04 01:49 AM
the 258's get a little winded when running that fast... with how old the engine is and with it burning oil i'd say thats pretty normal.
usually you won't see oil coming out the tail pipe until you hit about 1 quart every 1000MI
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6074 MB (Peak: 0.6765 MB) Data Comp: Off Server Time: 2026-06-07 10:34:02 UTCValid HTML 5 and Valid CSS
