Page 2 of 3 1 2 3
Re: AMC head and Delta cam installed, but.... [Re: Bigpoppax2] #527296 11/18/04 03:02 PM
Daniel_T Offline
Yeah the timeing thing is a big deal. HOwever Rob said it runs and sounds fine so it just don't sound like this is a timeing issue. I know if you take one of the wires off it will still run and have a slight vibe to it but it will not ideal like he says it does. I wish I can help you out here man but I don't have a clue.If you haven't got it by this weekend we can mess around with when I get there if you want. Oh yeah have you talk to jerry yet about this?
Later,
Daniel
"Thanks for the joy that you gave to me"
Re: AMC head and Delta cam installed, but.... [Re: Daniel_T] #527297 11/18/04 06:21 PM
mlclark Offline
Isuzu Moderator
This is dropping one hole while the other three are firing at the correct time. Mix up the wires and fire those plugs at the wrong time in the cycle and it will indeed make it act like it is trying to jump out of the engine compartment and leave.
Michael
Re: AMC head and Delta cam installed, but.... [Re: mlclark] #527298 11/18/04 06:25 PM
Daniel_T Offline
Michael
I agree completely But it would not idle like it should nore run like he is stating it runs.
Later,
Daniel
Re: AMC head and Delta cam installed, but.... [Re: Daniel_T] #527299 11/18/04 06:42 PM
mlclark Offline
Isuzu Moderator
Recognizing the fact that we are all just groping fish in the dark until ROB FIXES THE PROBLEM, it very well may "idle" depending on which wires are mixed up (only 2, maybe?) and how far off the dizzy is. Combine that with the relatively large rotating mass and it could smooth out some of the problems at idle. Add a load (rev it) and it's off to the races.
Michael
Re: AMC head and Delta cam installed, but.... [Re: mlclark] #527300 11/18/04 07:47 PM
RobG Offline OP
telling me to get off my arse once again and get to work, eh? well, i plan on giving it some attention tonight after work. i'll double and triple check the wires and firing order. i'll stop by my shop and grab the timing light. and if its still doing the mumbo jumbo by the end of tonight, i'll take a short video clip with sound so you can get a better idea of what i'm talking about.
...boy am i going to take lots of heat from michael if it turns out to be two mismatch wires! <img src="/forums/images/graemlins/rolleyes.gif" alt="" />
-Rob
Re: AMC head and Delta cam installed, but.... [Re: RobG] #527301 11/18/04 07:56 PM
Daniel_T Offline
You and me both. <img src="/forums/images/graemlins/ignore.gif" alt="" />
Later,
Daniel
Re: AMC head and Delta cam installed, but.... [Re: Daniel_T] #527302 11/18/04 09:03 PM
Bigpoppax2 Offline
Just to add some fuel to the fire mine wouldn't even begin to start when I put the wires on like the Haynes manual said. When I wired it according to the numbers off the dist. cap it worked like it should.
Re: AMC head and Delta cam installed, but.... [Re: Bigpoppax2] #527303 11/19/04 02:20 PM
RobG Offline OP
well michael... go ahead and say it! i told you so! I must regretfully bow down, i checked the plug wires last night and #1 and #2 were reversed. After swapping them out, idled just the same, but this time the shimmy and shakes were gone. so yes, I panic'd for nothing, and we're back in pretty good shape. now i just have to go back and adjust valve lash again from burning in the cam, and we should have this back on the road.
looking like if i make it to moab this year, i owe you yet another drink! <img src="/forums/images/graemlins/cheers.gif" alt="" />
Thanks everybody.
-Rob
Re: AMC head and Delta cam installed, but.... [Re: RobG] #527304 11/19/04 02:48 PM
Bigpoppax2 Offline
That's good, I'm glad you got it figured out, and it was something simple. <img src="/forums/images/graemlins/kewl.gif" alt="" />
See you Saturday.
Re: AMC head and Delta cam installed, but.... [Re: RobG] #527305 11/19/04 03:30 PM
Daniel_T Offline
NO NO NOOOOOOOOOOOOOOOOOOOOOOOOOOOOO!!!!!!!!!!!
Well I guess it is only proper that I do the same <img src="/forums/images/graemlins/rolleyes.gif" alt="" />. Good call Michael. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Rob you didn't have to come right out and say that though <img src="/forums/images/graemlins/ignore.gif" alt="" /> We could have keep it to ourselfs.lol
Anyways glad you got it going...
Later,
Daniel
Page 2 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6432 MB (Peak: 0.7537 MB) Data Comp: Off Server Time: 2026-06-20 22:54:04 UTC
