clogged grease fitting.... #527729 11/18/04 11:20 AM
CDUFF7 Offline OP
I have an 88 Toyota - I need a new grease fitting - they all look the same size - does anyone know what size and where to buy?
Re: clogged grease fitting.... [Re: CDUFF7] #527730 11/18/04 02:34 PM
I typically just take the one out, take it to the local True Value, and paw through their bins until I match it up.
Or, depending on how often you run into such problems, get one of these: Grease Zerk Cleaning Tool
Re: clogged grease fitting.... #527731 11/18/04 02:59 PM
CDUFF7 Offline OP
thank you, I am in Japan so I wanted to try ebay - anyone know the specifics on the size of an 1988 Toyota 4runner zerk fitting - ie: grease fitting?
Re: clogged grease fitting.... [Re: CDUFF7] #527732 11/18/04 05:55 PM
Sorry, missed your location....
Re: clogged grease fitting.... [Re: CDUFF7] #527733 11/18/04 06:10 PM
4Crawler Offline
Probably a few different sizes. As mentioned, pull it out and measure the diameter and go from there. I usually pick up a metric grease fitting assortment at the auto parts store:
http://www.midwayautosupply.com/manufacturerminorcategory.asp?Grease%20Fittings
You might also try cleaning it while you have it out, use a small punch to depress the ball in the end and a pin to auger out the hole in the base.
Re: clogged grease fitting.... [Re: 4Crawler] #527734 11/18/04 08:09 PM
ScottFW Offline
The assorted metric pack at my local parts store contains 6mm and 10mm zerks and says "fits Toyota," for whatever that's worth. Just eyeballing them, I'm guessing most of the 4runner's would be the smaller 6mm ones. Just an edumacated guess though, you'd have to measure to be sure.
I've never seen one of them fancy schmancy zerk cleaning tools before. Sounds like it does a good job, but it's a little pricey. The $35 might be worth it for a pro mechanic but a new zerk costs less than $1. <img src="/forums/images/graemlins/kewl.gif" alt="" />
'85 4Runner (mostly stock) <img src="/forums/images/graemlins/kewl.gif" alt="" /> | '94 Miata <img src="/forums/images/graemlins/smile.gif" alt="" /> | '98 Saturn SC2 <img src="/forums/images/graemlins/rolleyes.gif" alt="" /> | '12 Ford Fusion (wife's company car)
Re: clogged grease fitting.... [Re: ScottFW] #527735 11/19/04 03:51 AM
CDUFF7 Offline OP
thanks guys for all the info - I will be buying a new one or just salvaging the old one.
Re: clogged grease fitting.... [Re: CDUFF7] #527736 11/19/04 04:06 AM
87Toy4x4 Offline
one of my new balljoints wont even take any grease in the zerk even when i put a new one on. do you think its clogged? the guy told me they came pre greased but they came w/ a zerk fitting so he was full of it. i should of got another joint from him.
Re: clogged grease fitting.... [Re: 87Toy4x4] #527737 11/19/04 04:12 AM
CDUFF7 Offline OP
That is exactly my problem on the right side, but I do not think the ball joint is new, I am going to take the zerk off today and give it a good cleaning - I am getting ready for winter and want everything greased up.
Post deleted by little_joe [Re: 87Toy4x4] #527738 11/19/04 04:24 AM
PHP: 7.4.33 Page Time: 0.014s Queries: 16 (0.011s) Memory: 0.6345 MB (Peak: 0.7578 MB) Data Comp: Off Server Time: 2026-11-17 13:50:31 UTC
