Re: clogged grease fitting.... #527739 11/19/04 04:30 AM
CDUFF7 Offline OP
one of my new balljoints wont even take any grease in the zerk even when i put a new one on. do you think its clogged? the guy told me they came pre greased but they came w/ a zerk fitting so he was full of it. i should of got another joint from him.
Well they are pre-assembled with grease... the supplied zerk fitting is for future servicing of course... are you trying to grease these new ball joint after installation with the weight of the vehicle on them or are you jacking the front and taking the weight off the ball joints?
should I have to jack it up to grease that fitting?
Post deleted by little_joe [Re: CDUFF7] #527740 11/19/04 04:46 AM
Re: clogged grease fitting.... #527741 11/19/04 05:03 AM
CDUFF7 Offline OP
thank you very much, I will be following those steps then and keep my findgers crossed - a new ball joint sounds expensive?
Post deleted by little_joe [Re: CDUFF7] #527742 11/19/04 05:12 AM
Re: clogged grease fitting.... #527743 11/19/04 05:26 AM
CDUFF7 Offline OP
Thaks Thief, You obviously have experience in this situation. I really appreciate it. All in good from, Aye.
<img src="/forums/images/graemlins/patriot.gif" alt="" />
Re: clogged grease fitting.... [Re: CDUFF7] #527744 11/19/04 11:05 AM
CDUFF7 Offline OP
Thanks Thief! I just removed it with a 10mm Toyota wrench, sprayed it out with degreaser, checked it by pumping grease thru it with my grease gun, reinstalled and baaaam it worked. then I went on to grease the whole truck - man that felt good. I do it 3 times a year to keep all the grease somewhat fresh. Take it easy, Chris
<img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: clogged grease fitting.... [Re: ScottFW] #527745 11/19/04 02:46 PM
I've never seen one of them fancy schmancy zerk cleaning tools before. Sounds like it does a good job, but it's a little pricey. The $35 might be worth it for a pro mechanic but a new zerk costs less than $1. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Yep, you can replace a lot of zerks for the price of that tool. However, I've basically seen the tool around heavy equipment where it is not just the zerk, but the grease passage that gets clogged up. In that case, just replacing the zerk doesn't do you any good. The passage is still clogged.
Post deleted by little_joe [Re: CDUFF7] #527746 11/19/04 07:54 PM
Re: clogged grease fitting.... #527747 11/20/04 07:24 AM
87Toy4x4 Offline
im pretty sure i tried it w/ the vehicle lifted when the joint was new b/c i couldnt feel any grease in the boot. ill lift it tomm. and see if that works. also their is a gap in between the boot and the nut and my factory ones didnt have it. i dont know it thats normal or what. but its been 4 months now and i am still not able to get grease in the thing. that kinda worry's me.
PHP: 7.4.33 Page Time: 0.014s Queries: 15 (0.010s) Memory: 0.6255 MB (Peak: 0.7112 MB) Data Comp: Off Server Time: 2026-11-18 03:20:41 UTC
