Re: 99 Rodeo Automatic Gear Selecter Lock won't release [Re: LetsRodeo] #529253 12/04/04 11:46 PM
LetsRodeo Offline OP
This was an interesting problem. Originally I thought this was probably the shift lock relay. When I measured the resistance to ground on the negative side of the coil I saw ~35 OHMs. This sent me chasing a loose ground connection, but after further fault finding, it was actually the Park Position Detect Switch. The switch was not closing completely. After some coaxing and bending I got the thing to make, tested it and wala! It works. I'm back to normal operations. <img src="/forums/images/graemlins/kewl.gif" alt="" />
My suspicions about the key switch and shift lever were true. They are interlocked. When the key switch is in the ACC position you can press the button on the shift lever and move the lever where ever you want.
HereÆs a schematic of the circuit with some coarse sketches of the component locations.
The Electrical Troubleshooting Manual (from Helms Inc.) is an extremely helpful guide. Not only does it show the schematics for all the Rodeo/Amigo circuits it also shows pictures of where all the components are located as well as all the connectors plus the connector pin outs and wire colors. The shop manuals have been indispensable while DIM (doing it myself).
If you want something done right do it yourself two or three times!
LetsRodeo
1999 Isuzu Rodeo LS 4WD
3" CPL, 3" BL
LT265/75 16 TOYO Open Country AT
ShrockWorks Rock Sliders
Re: 99 Rodeo Automatic Gear Selecter Lock won't release [Re: LetsRodeo] #529254 12/06/04 01:09 AM
slappy Offline
That is great that you were able to take the time and figure it out. I might actually start digging in there now to see if I can make mine work also.
Great diagram, BTW.
<img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" />
-john
99 Rodeo 3.2L 4WD
PHP: 7.4.33 Page Time: 0.013s Queries: 15 (0.010s) Memory: 0.5967 MB (Peak: 0.6465 MB) Data Comp: Off Server Time: 2026-11-17 11:17:30 UTC
