Gen1 LWB Body Weight #530335 11/25/04 08:25 AM
Boertjie Offline OP
I need to lift the body of my 1989 Gen1 LWB off the chassis, but I do not have the weight of the body.
Will it be OK to hang the body by straps (recovery) through the windows, as this guy did? I saw it on Aussy forum:
1989 Exceed LWB
4m41 (3.2DiD TurboDiesel
5-spd Manual Tranny
2" lift
31" BFG A/T
Re: Gen1 LWB Body Weight [Re: Boertjie] #530336 11/25/04 02:39 PM
Tag Offline
I wish I could tell you the anser to your weight question. But notice he has the front fenders off and a few other things off the body as well. Pluss he has some kind of device under the strap to spread the weight wider then just the strap.
89 2dr 3.0 AT, manual hubs. 33x12.5 MT
gen 2 coils,Cranked front tbars
Dons rocker protection, Front/Rear Bumpers. ARB rear locker, 2" BL, Beefed up skid plates/trailing arms. Gen II uca, 2 Bouncy seats www.youtube.com/TagGeorge
Re: Gen1 LWB Body Weight [Re: Boertjie] #530337 11/25/04 06:28 PM
Vic Lee Offline
From the 89 FSM
There is a copy of the 89 FSM here.......
Manual
1990 Montero 2dr 3.0 Auto Lsd Front & Rear
Re: Gen1 LWB Body Weight [Re: Tag] #530338 11/25/04 10:10 PM
BobShaw Offline
I think the devices under the straps are to prevent damage to the door paint. The body must be less than 4000 lbs or only 1000 lbs per strap. Is'nt a 2" tow strap rated at 10,000 lbs? Remember, if you jerk it, the inertia load can be 3 times the static load. You should use a strap rated for at least 3000 lbs with the 4 point lift.
Bob Shaw
Re: Gen1 LWB Body Weight [Re: BobShaw] #530339 11/26/04 12:05 AM
FrankR Offline
It's probably not a good idea to run straps all the way through both sides and then try to lift with the strap(s). As the weight of the vehicle is taken up by a strap, the tendency is for the strap to press inward and could damage to the body framework through crush force. Much better to run a 4x4 through the windows, pad it where it makes contact and use an eye bolt w/fender washer and nut on each end of the 4x4, construct lead lines for 4-point lift from the eye bolts and connect the lead line(s) to the lift line(s).
Just my opinion.....
Frank
Re: Gen1 LWB Body Weight [Re: FrankR] #530340 11/26/04 09:56 AM
Boertjie Offline OP
Thanks for all the info, guys.
I suppose that approximately 50% of the total weight lies in the body?
VicLee,
Some of the files on the Russian site requires a user name and password. Can you help?
1989 Exceed LWB
5-spd Manual Tranny
2" lift
31" BFG A/T
Re: Gen1 LWB Body Weight [Re: Boertjie] #530341 11/27/04 03:07 PM
motero Offline
manual
lc190
99 Montero....15mpg! Sold (so sad)
02 Jetta TDI....48mpg!
03 2500 Ram QCLB Cummins....18mpg
02 2500 Yukon XL, We out grew the montero, at least it has one locker.....13mpg (sold)
01 montero limited
Re: Gen1 LWB Body Weight [Re: motero] #530342 11/29/04 07:33 AM
Boertjie Offline OP
Thankx for username & password
1989 Exceed LWB
5-spd Manual Tranny
2" lift
31" BFG A/T
PHP: 7.4.33 Page Time: 0.017s Queries: 15 (0.012s) Memory: 0.6231 MB (Peak: 0.7220 MB) Data Comp: Off Server Time: 2026-11-18 13:19:25 UTC
