Toe in/out adj on rear?
#530582
11/26/04 06:25 PM
I just came from Tire Kingdom to get my 02 Monty aligned.Its wearing the inside of the rear tires and they said no toe in / out adj on the rear.There is adjusters on the bottom arm and the upper arm,what do they do?
90 Amigo,Front 10 bolt with powertrax locker,Rear Dana 44 with Detroit Locker at 5:38.1 R&Ps,Pro Comp MT's 33x12.5 on 15x8 black Rockcrawlers,with a 3" suspension lift.Pro Comp steering Stabilizer.Warn M8000 winch in a ARB bullbar.
Re: Toe in/out adj on rear?
[Re: 90amigo]
#530583
11/26/04 06:48 PM
If it's independent rear suspension, then there would only be camber and caster. Toe is technically a member of the steering system and I don't believe that Mitsu has anything like quadra-steer.
[Re: DaphneD]
#530584
11/26/04 08:52 PM
Actually, if there is ajustments on a non steering rear, they would be camber and toe, Caster is the one dealing with steering. <img src="/forums/images/graemlins/cheers.gif" alt="" /> Just a littele mixed around. I will check my huntermachine real quick and post my findings. <img src="/forums/images/graemlins/patriot.gif" alt="" />
[Re: wyleone]
#530585
11/26/04 10:20 PM
The Alignment machine ilistrated that there are two cam eccentrics on the inside of the upper control arm, in the rear, that are used to ajust camber and toe. This is off of our 2004 model Hunter S811. So toe can be ajusted in the rear of the independant rear suspension Montero. <img src="/forums/images/graemlins/cheers.gif" alt="" />
[Re: wyleone]
#530586
11/26/04 10:52 PM
Actually, if there is ajustments on a non steering rear, they would be camber and toe, Caster is the one dealing with steering. <img src="/forums/images/graemlins/cheers.gif" alt="" /> Just a littele mixed around. I beg to differ.Someone tell me if I'm completely crazy, but the last time toe was adjusted on my vehicle, it was done so by adjusting the tie rods, which are steering components. Caster is a balance between ball joints. I don't see the connection between those and steering? <img src="/forums/images/graemlins/confused.gif" alt="" /> I have to admit though, I am no officianotto(sp?) of IRS. <img src="/forums/images/graemlins/drunk.gif" alt="" />
[Re: DaphneD]
#530587
11/26/04 10:57 PM
toe in toe out is affected by your tie rods.... which only adjust that. Steering adjustment is done on the draglink.
the toe in toe out adjustment is inherently tied to steering, but not really a steering adjustment.
/\toe in \/ toe out. like that.
[Re: DaphneD]
#530588
11/26/04 11:03 PM
When was that last time you aligned a RWDvehicle w/ rear independant susp? or a front wheel drive? Right on you screen it gives you: Rear toe and rear Camber. A ball joint is predominatly a steering component. Altough used in non steering situations. The rear of an independant susp vehicle does not always have ball joints. Caster is a balance between ball joints. I don't see the connection between those and steering? Hmmm
[Re: wyleone]
#530589
11/26/04 11:11 PM
Easy now. I know I'm not an expert on IRS, but I am trying to understand. And sorry, I misread some of the lingo above.
[Re: DaphneD]
#530590
11/26/04 11:18 PM
Peace and clarification. Here is Hunters link to caster and measurement of caster. <img src="/forums/images/graemlins/kewl.gif" alt="" /> Hunter: caster <img src="/forums/images/graemlins/cheers.gif" alt="" /> Sorry if I jumped off the handle <img src="/forums/images/graemlins/shiner.gif" alt="" />.
[Re: wyleone]
#530591
11/26/04 11:25 PM
Holy BeeeeJEAAAAAsus Thats alot of forumlas and Goooblahhhh.
I am going back to the garage with DougB, and we are going to beat rocks together. <img src="/forums/images/graemlins/notooth.gif" alt="" />
