Re: Noisy lifters after new ring and bearing job
[Re: solarcrew]
#533465
12/03/04 07:29 PM
Well, I'm going to be poking around in there tonight and see what I can find. If it's a new rocker assembly, then so be it. I only need to keep this truck another forty years or so <img src="/forums/images/graemlins/shocked.gif" alt="" />
2000 Tacoma SR5 - Bone stock 'cept a little bling. 2000 Tacoma SR5 - Bone stock.
[Re: GeriatricToy]
#533466
12/03/04 08:30 PM
Real easy to check alignment of the rocker in relation to the valve tip. Pull the adjustment screw out of the rocker...the hole should be centered directly over the tip.
As soon as the valve cover is off and you start looking any rockers that are out of alignment should be obvious though. Currently have the valve cover off my original 81' 22R in the Celica. Steel rockers instead of aluminum and quiter than a mouse cutting the cheese...would you believe that a 24 year old engine that has never had any internal work is showing no wear on the cam/rockers? The intake side adjustment screws are just starting to see the hourglass pattern (prolly from being too tight, had to loosen things up) and all 8 were dead nut center over the tips of the valves. Compression check last night revealed 155 psi across all 4 cylinders too. <img src="/forums/images/graemlins/kewl.gif" alt="" />
88' 4x4 *22R-EB Gen II* 87' $Runner *22R-EB Gen I* 85' Sillyca 22R-Esq  "I LIVE IN MY OWN WORLD...THEY KNOW ME WELL THERE"
[Re: Esquire812]
#533467
12/03/04 09:12 PM
I'm really leaning toward the rockers because of what some of the other fellers symptoms are exactly what's going on with mine, specifically the "sometimes it's quiet, sometimes you can't shut her up". Well if it is the rockers, Guess what? EB sold me some adjusting screws from a perfectly good rocker arm assembly he can sell me. <img src="/forums/images/graemlins/kewl.gif" alt="" />
[Re: GeriatricToy]
#533468
12/03/04 09:33 PM
Old trick..........disassemble rocker shafts.....rotate shafts 180 degrees and reinstall. May have to drill/tap holes for lock screws.
While apart, examine shafts for grooving and egg shape. Do same with rocker inner bores.
While you are fiddling with it, get yerself a tube of machinist's blue(prussian blue).....or use ink from ball point pen shaft....Apply thin coat of blue/ink to rocker screw tips and cam lobes....roll engine over at least 2 full revs...then examine valve stem tips and rocker follower pads to see where blue transferred....You may discover that cam lobes are unevenly worn. And it will also indicate if screw tips travel to stem edge when actuating valves.
#533469
12/03/04 09:36 PM
P.S.
To get ink from ball point pen shaft, just heat with cig lighter and it will run out....
#533470
12/03/04 10:27 PM
cool trick, yodaddy...thanks.
1994 4x4 22RE W56 truck
#533471
12/03/04 10:51 PM
Yodaddy, you just want my rocker assembly that Eb has waiting for me don't ya? <img src="/forums/images/graemlins/lol.gif" alt="" /> I'm pretty sure Ican procure some machinists die at work. Fix my irritation and save some cash all in the same day? Say it isn't so. Thanks for the tip.
#533472
12/03/04 11:03 PM
[quote]Old trick..........disassemble rocker shafts.....rotate shafts 180 degrees and reinstall. May have to drill/tap holes for lock screws.
>>>*....Uhhhh.....(*I wouldn't do that if I were you, look at where the oil holes are....).. .*EB
*Beats the he** outa me!....*LOL**...
[Re: engnbldr]
#533473
12/03/04 11:40 PM
>>>*....Uhhhh.....(*I wouldn't do that if I were you, look at where the oil holes are....).. .*EB <img src="/forums/images/graemlins/smile.gif" alt="" /> Thats what I was thinking....figured I leave my $1.93 out of it though since Im such a young pup and all....ya know. LOL ~Darin <img src="/forums/images/graemlins/baby.gif" alt="" />
[Re: Esquire812]
#533474
12/04/04 01:53 AM
Alright, I'm going to play it safe and take a peek into the holes. I was going to go out tonight but man-o-man it got cold. it wold take an hour to get the garage warm so I'm putting it off till tomorrow.
