Rotor question #53361 05/28/03 10:48 PM
Arnold Offline OP
First off I searched and could find the info I needed. I purchased a used Toyota mini axle from someone locally. I am in the process of totally rebuilding it. I have it down to replacing the brake rotors. I noticed that it has two different styles of hubs and rotors on it. One set: the hub is held to the rotor via 2 bolts and all 6 lugs are driven thru it. The other set: 6 bolts held the hub to the rotor. What is up with this? Is one set from another year axle? I was told the axle is an 85 model and it does have the full gusset. Can anyone tell me what year the other rotor and hub are from? I am having a hell of a time getting replacement rotors <img border="0" title="" alt="[Mad]" src="images/icons/mad.gif" /> Thanks for any input!
98 4runner Limited, 33's and stuff
85 4runner - 4 sale
85 Toy pickemuptruk, EFI, winched, locked, rust
Re: Rotor question #53362 05/28/03 11:48 PM
Adam F Offline
I'm in the same boat. I am going to have to have the studs pressed out and then back in. As far as I know, 79-80 hubs work the same way as the IFS hubs, you just have to remove the 6 bolts, but 81-85 solid axle rotors, the wheel will need to be pressed out of the rotor.
<small>[ May 28, 2003, 06:49 PM: Message edited by: Adam F ]</small>
97 4R, stock, daily driver
PHP: 7.4.33 Page Time: 0.006s Queries: 14 (0.004s) Memory: 0.5864 MB (Peak: 0.6347 MB) Data Comp: Off Server Time: 2026-06-20 05:12:57 UTC
