This is really old, but I'm bumping it cause I'm also interested in new shocks for my 97 Rodeo for mainly street driving.
Because you said ômainlyö, I will assume that
some off-road use will occur û therefore, youÆll probably want a somewhat stiffer-than-stock set of shocks. --- This will afford the steadiness that you would want while out on the trails - while at the same time; provide firmer / more stable handling characteristics on the road.
Although I have never run a set of them myself,
Old Man Emu shocks have an excellent reputation, and should suit your needs quite well. --- They provide a good ride - while at the same time, they are extremely durable and reliable for when things get rough. --- They do cost more than your average shock, but judging by all of the high praise that the get, they're worth it.
Personally, I have a set of
9-way adjustable Rancho 9000x shocks. --- These are also a bit pricy, but very good and worth every cent, especially if you plan on being on
and off-road a lot. --- Their adjustability allows you to choose the setting that best suits the terrainà On-road, you can dial them back for a softer ride û and then as soon as youÆre ready to hit the trails, you simply dial them up to a stiffer setting to help keep the vehicle from bouncing down on top of anything. --- With the optional air-powered Interior Control Unit, you donÆt even have to get out of the driverÆs seat to change the settingsà you just hit a button, and æwoooooooooshÆà stiffer shocks! <img src="/forums/images/graemlins/kewl.gif" alt="" />
Although, in all fairness, I believe I am one of the few people out there that has the Remote Control Unit who doesnÆt suffer from any of the typical (notorious?) air leaks that are known to plague the system)
In any case, those are probably the Top Two Choices. û Hope it helps! <img src="/forums/images/graemlins/kewl.gif" alt="" />
Cheers! <img src="/forums/images/graemlins/cheers.gif" alt="" />
Smiley
