questions about 2.2 TD engine #534674 12/06/04 04:20 PM
crossbones Offline OP
Hello to everyone. First let me say there seems to be a lot of great guys with a lot of knowledge on this forum. May I pick your brain some before I get manuels on the 86 Trooper TD that I just bought. The Trooper has a lower end engine knock, so out it will come for a look see. My questions are these as I have collected several pickups with the non turbo engines including spare parts and manuels. What engine parts are different between the non turbo and turbo engine. I have read post about the pistons and rods being different, but what about other things as the head, cam, block, crank, injection pump or any other part that there is a problem with interchange. Last a opinion question: As I have a non turbo engine on the stand ready for assembly, how would that combo do in the heavier trooper body. Looking for fuel mileage more so than power as 55 MPH is just fine for an "old fart" like me. Thanks in advance. <img src="/forums/images/graemlins/cheers.gif" alt="" />
1982 Luv Diesel 4X2
1982 Luv Diesel 4X4
1981 Luv diesel 4X2
1983 Isuzu Diesel 4X4
1986 Trooper TD
Re: questions about 2.2 TD engine [Re: crossbones] #534675 12/06/04 07:50 PM
turboDIESELtrooper Offline
I am actually going to do what you asked about. I have bought an Isuzu Trooper turbo diesel with no engine or transmission. What I will be doing is putting in the later model non-turbo diesel engine with 62 HP. And then I will use the 5-speed 4WD transmission that came on the turbo diesel C223T. What I have realized with my setup is the Trooper's top speed will be 50-55 MPH, but will get at least 32-35 MPG. I want to stay away from the turbo diesel engine and its connecting rod flaw in the Trooper. Since you have a non-turbo diesel engine that is ready to be put in a vehicle, you have another option for an engine in your Trooper if you don't want to use the turbo diesel engine. Good luck with what you decide and if you have any other questions feel free to ask. I'll answer if I can help.
PHP: 7.4.33 Page Time: 2.975s Queries: 15 (0.004s) Memory: 0.5893 MB (Peak: 0.6381 MB) Data Comp: Off Server Time: 2026-05-30 01:14:13 UTC
