TRD locking diff problem #535954 12/09/04 02:50 AM
mikemike Offline OP
Hi All,
I'm still shopping. Looking at a '98 SR5, TRD, 84K miles. It has a couple of problems I'll have to get fixed if I buy. When I try to engage the rear diff, the indicator light blinks, but never stays on. I read the owners manual and followed the instructions there on how to engage, I had it in 4L. The manual says that it is not engaged unless the light quits blinking. Any ideas what coud be wrong, and how expensive to fix? Too many possiblilities to list?
Thanks.
Re: TRD locking diff problem [Re: mikemike] #535955 12/09/04 03:21 AM
sometimes you have to take a sharp turn left to right to get the teeth to lock in
mine i have needed to spin the tires a little bit to get it engaged
Re: TRD locking diff problem #535956 12/09/04 03:39 AM
same here
Re: TRD locking diff problem #535957 12/09/04 06:42 AM
spin the tires a bit, or go foward a few feet or back until it kicks in.
Re: TRD locking diff problem #535958 12/10/04 02:32 AM
Same situation on my '02 TRD Tacoma. Things have to line up and engage back there and there is also the computer intervention. I learned to simply trust the truck, engage it and go for it. It eventually engages when it's actually needed - when one of the back wheels start spinning or a wheel lifts over bad bedrock stairs.
Re: TRD locking diff problem [Re: mikemike] #535959 12/10/04 11:42 PM
The lock have a sensor and it may be in trouble. With only the key in the switch and not the engine running, keep one person outside of the truck and press the lock button. If you hear it lock, it may work! I have this problem with my!
Re: TRD locking diff problem #535960 12/13/04 04:19 AM
mikemike Offline OP
Thanks. I went back and tried turning a bit and it locked right in. May have found my truck!
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6005 MB (Peak: 0.6755 MB) Data Comp: Off Server Time: 2026-06-21 09:34:55 UTC
