Page 1 of 3 1 2 3
1st Gen Amigo Cluster swap (XS w/tach) #536703 12/10/04 10:46 PM
Has anyone or does anyone know if you can install the Amigo XS model's instrument cluster (With tachometer) into the non-tach equipped Amigo without having to re-wire? If it does need wiring ran, is it a major job or something I can handle with my Haynes/Chilton manuals?
I've been wanting to have the tach without adding a non-factory gauge pod.
Re: 1st Gen Amigo Cluster swap (XS w/tach) #536704 12/10/04 11:28 PM
Sc0rp10n Offline
hmm i'll be interested to see the answer to this also.
Nick
2000 XJ Classic - Classically a POS
1994 Isuzu Amigo XS -Sold
1972/3 CJ5 Glass body, 5" lift 34's. 5 years of work coming to an end.
Re: 1st Gen Amigo Cluster swap (XS w/tach) #536705 12/11/04 12:17 AM
houlster Offline
Isuzu Moderator
Yes, it plugs right in. You can use a GM V6 rodeo cluster as well, but you'll have to adjust the tach to read right if you do. The Amigo one is a 5 minute swap though.
--Dan
Re: 1st Gen Amigo Cluster swap (XS w/tach) [Re: houlster] #536706 12/11/04 07:55 AM
Thanks for the good news!
Re: 1st Gen Amigo Cluster swap (XS w/tach) [Re: houlster] #536707 12/11/04 04:07 PM
Sc0rp10n Offline
Found this when i was looking for XS parts through google
http://www.houlster.com/amigo/how-to.htm
Nick <img src="/forums/images/graemlins/patriot.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: 1st Gen Amigo Cluster swap (XS w/tach) [Re: Sc0rp10n] #536708 12/11/04 04:14 PM
Sc0rp10n Offline
i already feel stupid, but i'll keep that link up anyways haha, the search brought me straight to that page so i didn't realize which site it actually was....wonder who the author is, man must be a genius <img src="/forums/images/graemlins/wink.gif" alt="" />
Re: 1st Gen Amigo Cluster swap (XS w/tach) #536709 12/11/04 04:39 PM
Sc0rp10n Offline
Re: 1st Gen Amigo Cluster swap (XS w/tach) [Re: Sc0rp10n] #536710 12/11/04 05:14 PM
houlster Offline
Isuzu Moderator
<img src="/forums/images/graemlins/smile.gif" alt="" /> yes, that's my site. I would've posted the link, but it appeared to be down when I was trying to make the post.
--Dan
Re: 1st Gen Amigo Cluster swap (XS w/tach) #536711 12/14/04 05:48 PM
90amigo Offline
http://www.partrequest.com/junkyards.htm
I got a used one for $35. Went to a local yard and got the oil sender with a handfull of misc parts for $20.
I swapped my speedo in it since it had less miles then the new/used cluster.
90 Amigo,Front 10 bolt with powertrax locker,Rear Dana 44 with Detroit Locker at 5:38.1 R&Ps,Pro Comp MT's 33x12.5 on 15x8 black Rockcrawlers,with a 3" suspension lift.Pro Comp steering Stabilizer.Warn M8000 winch in a ARB bullbar.
Re: 1st Gen Amigo Cluster swap (XS w/tach) [Re: houlster] #536712 01/24/05 07:23 AM
mlclark Offline
Isuzu Moderator
Just some info to be had. I finally tracked down that pesky pot and here are some numbers for those who might want to just drill the hole and not disassemble the cluster.
As is said in Dan's article, the general location is above and behind the tach face. A good place to start would be to drill a small hole 1 3/4" from the side (left, facing the front of the cluster), and 7/8" from the back edge. This puts you just to the inside edge of a lump on the white plastic back cover.
I ended up going with a 3/8" hole, but that is because my small screw drivers have a stubby shank on them. Drill what you need and then seal it up when you are done.
Good Luck,
Michael
Page 1 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6356 MB (Peak: 0.7578 MB) Data Comp: Off Server Time: 2026-06-14 07:35:39 UTC
