Re: 3.0 running rich/high idle #537370 12/16/04 12:05 AM
L
lochabay Offline
First, check your codes. I had a similar rich-running problem and did not check trouble codes until I had done many other things. Codes showed a bad air flow meter and barometric pressure sensor (both are one unit). Replaced that unit and mileage went from 9 mpg (stinko) to 14-15 mpg, so it can make a lot of difference. The car operated normally except for the rich mixture and there was absolutely no indication that the MAS meter was not functioning properly.
Re: 3.0 running rich/high idle [Re: MontyMcV] #537371 12/16/04 04:25 AM
52degrees Offline
Definately. Not saying that it is all of your problem, but it could be. also check your diverter valve.
If you decide to seal up any leaks, DO NOT use silicone sealant. It gets onto the O2 sensor and destroys it. Then the problems really start.
Check codes first, like everybody keeps saying. You may or may not have a lean exhaust code. Fix exhaust leaks first before looking elsewhere.
Clay
KG6VNX
Re: 3.0 running rich/high idle [Re: 52degrees] #537372 12/16/04 06:22 AM
Just have to get around to picking up a analog meter... <img src="/forums/images/graemlins/rolleyes.gif" alt="" />
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.006s) Memory: 0.6006 MB (Peak: 0.6538 MB) Data Comp: Off Server Time: 2026-06-23 06:08:20 UTC
