petroleum resistant rubber gasket #537719 12/14/04 01:23 AM
I am trying to revive some old jerry cans and I need to replace their gaskets. Any suggestions where I can find the proper rubber, the proper type, that doesn't melt in contact with gasoline/petrol? I had some messy experiences with rubber melting and jery cans leaking all over..:(
what's better betwen silicon compounds, neoprene, rubber? if anybody here manufactured their own gaskets out of something that can be easily found at the local hardware store and it worked without leaks, i would deeply appreciate the info. Obviously, there are some trustworthy companies manufacturing custom seals and gaskets out there but since I would order a very limited amount it is more feasible to go the hardware store route.
thanks
w.
Re: petroleum resistant rubber gasket #537720 12/15/04 04:56 AM
azrain Offline
Try and find a small remnant of Viton R at a local plastic supply house. We use that for fuel seals on turbine engines, should be plenty stout enough for your application.
Mike
Re: petroleum resistant rubber gasket [Re: azrain] #537721 12/15/04 05:03 AM
Mike
Thanks Mike, I should do that.
Viton R.
regards,
w.
Re: petroleum resistant rubber gasket #537722 01/25/05 03:00 AM
A
Albin Offline
Try Major's Surplus or Cheaper than Dirt. If you only need a couple, I got 10 or so several years ago and can give you a couple if you still need them (I assume you're talking about the old military "Blitz" cans). IM me.
Bonus: Everything you wanted to know about Jerry Cans:
http://www.rocketcityrockcrawlers.com/memberstuff/al/JerryCanPaperV1.2.pdf
Thanks,
Al
KI4Dxx
?85 Toy 4Runner: 35x12.50 BFG MTs, manual, Kenwood 2M, 140 amp alt, 26 gal aux fuel tank
'06 F-350 SRW 6.0 PSD XLT 4x4, manual, Yaesu 2m, 140 amp alt, 90 gal aux fuel tank, Air Ride air bags
Re: petroleum resistant rubber gasket [Re: Albin] #537723 01/25/05 05:00 AM
YOTA88 Offline
azrain is right. look for viton gaskets,seals or o-rings. I manage a facility that handles haz-mat and we use alot of viton gaskets and seals. they handle petroleum products very well.
SAS88TOY, caged, lockered, Longfielded, etc. etc. etc. blah blah blah!!!
2005 Tundra Quadcab.
Re: petroleum resistant rubber gasket #537724 02/04/05 06:41 PM
A
Albin Offline
thanks
w.
So, didja get fixed up?
KI4Dxx
Re: petroleum resistant rubber gasket [Re: Albin] #537725 02/04/05 06:55 PM
A
Albin Offline
KI4Dxx
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.005s) Memory: 0.6124 MB (Peak: 0.7062 MB) Data Comp: Off Server Time: 2026-10-22 06:53:14 UTC
