Page 1 of 5 1 2 3 4 5
Where to mount my Hi Lift Jack #537792 12/14/04 03:03 AM
W
wyojeeper Offline OP
I got a question for all you trail hounds. I'm looking for a good spot to mount my Hi Lift in my 91YJ. I don't have any racks or aftermarket bumpers or the like. I bought a 4xRac tonight, and really don't want to mount the jack in front of my bumper. Mounting on the rear bumper isn't an option, due to a receiver hitch being in the way. Anyone ever mount their jack on top of their front bumper?
Re: Where to mount my Hi Lift Jack [Re: wyojeeper] #537793 12/14/04 03:54 AM
i have seen that, some guys i wheel with have drilled 2 holes through their rear roll bars and mounted it with bolts across the rear roll bars, i have mine in the back behind the seat in a highlift bag. it works but i have a little more room back there than a yj does.
Re: Where to mount my Hi Lift Jack #537794 12/14/04 03:56 AM
derangedcj Offline
If you have to stock front bumper you can mount it there. You can either get some plates they sell the bolt onto the bumper or you can fab some. Its lays on its side. I will get a picture of mine in the morning and post it. Or you can mount it on the back bumper pointing up. You bolt it to the bumper and weld a bar to also attach it to the spare tire mount. <img src="/forums/images/graemlins/kewl.gif" alt="" />
83 CJ-7 3 in suspension. All problems currently fixed. Just Everyone Elses Parts. JEEP
Re: Where to mount my Hi Lift Jack [Re: derangedcj] #537795 12/14/04 05:24 AM
I mounted mine inside the cab just behind the seats using 2 brackets that bolt to the floor [or on top of a bumper if you like] and it stays clean and dry.
Re: Where to mount my Hi Lift Jack #537796 12/14/04 05:57 AM
BigJim Offline
How much luck do you guys have using that tractor jack on flimsy jeep bumpers? I'd have to weld some jack perches on my jeep before I would be comfortable jacking it up with one of those. Don't get me wrong I have one of em. But I also have a tractor <img src="/forums/images/graemlins/smile.gif" alt="" />
Big Jim
Re: Where to mount my Hi Lift Jack [Re: BigJim] #537797 12/14/04 06:14 AM
i'm planning on mounting mine on the spare tire.
i let my flimsybumper deform, since i use them to push people around.
Re: Where to mount my Hi Lift Jack [Re: BigJim] #537798 12/14/04 06:22 AM
W
I've used mine plenty of times, and haven't had a problem with "flimsy" bumpers at all. Last winter we got hung up in my cherokee when we slid off a trail into deep snow. We just jacked it up with the hi lift and pushed it sideways off of the jack to move it back onto the trail. It took several repetitions , but the bumper sustained zero damage. The bumper on my YJ seems a heck of a lot stouter than the one on my cherokee.
I'm leaning towards mounting the 4xrac on top of my bumper, up front. I just need to make sure I can get the mounting plates to fit o.k. on top of the bumper. Hopefully I won't have to remove the front bumper to mount the rack.
I've also considered mounting it on top of my hard top, but I'm reluctant to drill holes in my top to mount the 4xrac.
Re: Where to mount my Hi Lift Jack [Re: wyojeeper] #537799 12/14/04 06:44 AM
BigJim Offline
And what jack do you'ns carry for the BACKEND of your jeeps?
BJ
Re: Where to mount my Hi Lift Jack [Re: BigJim] #537800 12/14/04 07:16 AM
you know those circulare things.... just let them bend too.. who cares?
Re: Where to mount my Hi Lift Jack [Re: wyojeeper] #537801 12/14/04 07:55 AM
ive got a 3x5x1/4 bumper with 2x2x1/4 uprights that i
fabbed up front, ive found that mounting the jack behind
the uprights is a great spot. these bumpers sale for
about $400 so i took a picture of one i liked an fabbed
it up for about $50 an had 5/16 plate braked to fit
outside frame rails for winch plate, their are plenty
of holes up front to bolt up brackets so my winch plate
an front bumper are all welded into one piece that can
be unbolted. i also welded in tow hooks an fabbed tow-
bar that is rear tire carrier, when i put my full floater
in rear i took old 2 piece axle an cut off about 6" of
axle with spindle an welded to towbar so towbar mounts uprite on back an is allways with me if i need it. ive
fabbed a bunch of these bumpers in my area an now everybody
can use towbar if they need it.
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6299 MB (Peak: 0.7520 MB) Data Comp: Off Server Time: 2026-06-10 02:17:14 UTC
