Prothane Body Mount Install...Any Tips?
#538073
12/14/04 02:53 PM
I'm going to install these on my 85 4runner over the weekend. Is there anything I need to look out for during installation? I've installed a 3" BL before on another vehicle and this looks pretty simple. Maybe a seized bolt or two? Thanks.
Re: Prothane Body Mount Install...Any Tips?
[Re: Runningman]
#538074
12/14/04 06:23 PM
I have a brief description on my web page. Main issue will be if you are using the stock body mount bolts, the washers supplied in the kit will not fit, holes are too small. Either drill them out to fit (10mm - I pre-drill all the bushing kits I make) or get some 3/8" dia. body mount bolts to replace the 10mm bolts.
[Re: Runningman]
#538075
12/14/04 08:22 PM
i would definitely say rusted/seized bolts will be your problem. if you have new bolts, you dont have to worry about twisting them off.
[Re: 4Crawler]
#538076
12/20/04 03:22 PM
I re-used the stock cab bolts and drilled out the washers. Luckily, none of the bolts were seized and using the Hi-Lift to jack up the body is a good trick. Easy install.
The truck feels much more rigid and all the rattles are gone <img src="/forums/images/graemlins/kewl.gif" alt="" />. I can really feel the suspension work now, great upgrade.
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.008s) Memory: 0.5972 MB (Peak: 0.6552 MB) Data Comp: Off Server Time: 2026-11-17 09:54:31 UTCValid HTML 5 and Valid CSS
