Repairing Fuel Filter Primer Pump on Isuzu #538957 12/16/04 03:38 AM
Paul223 Offline OP
kravdraa asked how I fixed my primer pump so here goes.
First you need to grind the crimped flange off of the formed sheetmetal cover. Then you will need to remove the two flapper valves and clean and or straighten them so they can seal to the aluminum casting.
Then, you will need to reassemble this thing. This will require a clamping method. I made some aluminum rings which work very well and can be undone whenever the pump might need service again. Making the rings will require a lathe and a drill press. Not much else. Might be able to do it with hand tools.
I am attaching three photos to show what I am talking about.
Here is the finished filter.
Here are the rings.
And here is a sketch of the rings to help anyone make them.
Hope this fixes a ton of bad pumps..
Paul
Re: Repairing Fuel Filter Primer Pump on Isuzu [Re: Paul223] #538958 12/17/04 02:10 AM
This is a great repair - very impressive <img src="/forums/images/graemlins/kewl.gif" alt="" />. It never ceases to amaze me to see the quality of work out there in folk's garages. I see stuff like this and I feel like a hack.
I do have an Atlas 6" lathe. Even though I purchased a new pump from Jerry, I may try this to fix my old one just to have a spare.
NCDiesel
Re: Repairing Fuel Filter Primer Pump on Isuzu [Re: Paul223] #538959 12/17/04 04:01 AM
JLEMOND Offline
GREAT REPAIR SET UP PAUL , THIS IS WHAT THE FACTORY SHOULD HAVE DONE 20 YEARS AGO , AND SOLD THE TOP GASKET AND A VLV PLATE FOR A FEW DOLLARS INSTEAD OF THE ALMOST 100.00 THE WHOLE UNIT COST , GOOD WORK I AM GOING TO KEEP THIS IF YOU DON,T MIND JERRY
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5923 MB (Peak: 0.6467 MB) Data Comp: Off Server Time: 2026-06-07 11:22:28 UTC
