Re: high steer probs [Re: DirtyHarry] #540103 12/20/04 04:54 AM
4Crawler Offline
Plus shackles up front are not known for their ride and/or handling qualities. For sure have a shop check the caster angle and then shim it back to a reasonable value if it is off.
Re: high steer probs [Re: 4Crawler] #540104 12/20/04 06:58 AM
bigamigo Offline OP
i have thought of puttin in a cross bar from the pinion to the frame like a track bar in a 4 link and as far as the shakles if i go any smaller i loose the hight from spring eye to spring eye the front is a .50" down do you think a shim will take care of most of it ??????? better detailed pics tomorrow <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: high steer probs [Re: bigamigo] #540105 12/23/04 01:24 AM
bigamigo Offline OP
new pics at the amigo site better pics <img src="/forums/images/graemlins/cyclops.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/patriot.gif" alt="" /> <img src="/forums/images/graemlins/patriot.gif" alt="" />
Re: high steer probs [Re: bigamigo] #540106 12/23/04 10:50 PM
i found my problems.. when i put my truck on a buddies lift
and.. went lock to lock.. but.. actually push a bit on each lock. The axle on my truck would shift about an inch! it was due to the Long Shackles i had (two pieces of plate, not connected). I later welded a section of tubing inside.. giving it a bit more lateral ridgity. It was like night and day after doing that.
Apparently my rear sways a bit too due to the same circumstances but it was not noticable to me when i drove.
Re: high steer probs #540107 12/24/04 12:00 AM
4Crawler Offline
I find about 2" over stock shackle length is where bracing helps. On the front axle, bracing makes for a more solid steering setup.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6165 MB (Peak: 0.6941 MB) Data Comp: Off Server Time: 2026-06-17 10:32:11 UTC
