Front Drive shaft for SAS
#541627
12/22/04 05:06 AM
Ok guys, almost there... i got the custom brake lines made today and bled the system. only thing i'm missing is my steering rod and a driveshaft. I sold my stock front Dshaft a while back to fund this SAS <img src="/forums/images/graemlins/drunk.gif" alt="" /> So should I get a Toyota IFS shaft and have it modifided, or just take it the local drivetrain places and have them make a complete custom one? will a Tacoma V6 front Drive shaft work for mod'n? what's the best plan of attack here? on the axle i have a yoke that takes U bolts (1330? U joint I think) and on the Tcase I have the stock Yota flange. I have the V6 set up.
94runner: Dana 44 SAS, 35's, Lockers, gears, winch, rock rails, bumpers, 3"BL, drivetrain lift, Budbuilt cross member, centerforce clutch and MORE! ***FOR SALE*** $8,500 -1985 Supra (STOCK!) FOR SALE $4,000 www.celicasupra.com
Re: Front Drive shaft for SAS
[Re: bkg]
#541629
12/22/04 09:25 PM
yeah call jesse.he made mine up.thought the cv was going to be what was needed but he said no single joint will work better for me.use the cv for rear shaft.i have had my front driveline through some nasty stuff and no damage and runs smooth.i did have to use a non cv flange though on my t-case.
94 toy truggy rolling on tons
>>>>>>>>www.Rightcoast4x4.com<<<<<<<< Rockcrawling for the eastcoast.
[Re: 94krawler]
#541630
12/23/04 04:28 AM
How much $$$ did that set you back? I'm in the same situation....but I still have my donor front shaft as well as the IFS one.
JT
If Mad Max had a 4runner...
[Re: TexJeff87]
#541631
12/23/04 06:40 AM
i dont remember.call jesse and he will give you a price.alot of times his machine picks up.leave a message he will call you back.BTW i got the moster thick tubing on mine.
[Re: 94krawler]
#541632
12/24/04 07:42 PM
make a square shaft-cheap and works great
Rome 1994 Toyota 4x4 SAS pickup/2RZ/R151F=244:1! 1987 Toyota SAS pickup 37" MTR's 1993 Nissan NX2000 Dropped pocket rocket
[Re: TexJeff87]
#541633
12/24/04 08:06 PM
How much $$$ did that set you back? I'm in the same situation....but I still have my donor front shaft as well as the IFS one.JT I think about 275-300 dollars. It would be best to call Jessie and give him the details of what you need!!! <img src="/forums/images/graemlins/smile.gif" alt="" />
"Serenity through Sobriety"
[Re: OOP'S]
#541634
12/24/04 10:55 PM
a self-made square shaft is economical... but I wouldnt use in high torque situation. Id say only lighter vehicles with under 100 hp and close to stock tires/gearing. Seen a lot of them used successfuly on Suzuki's...
Michael J. Carsner proud driver of "Aint Pretty"  37 boggers, 571 gears, Detroit+Lock-Rights, 20R stage 1 LC Engineering head on 22R motor. MUD!!! Its whats for dinner!!
[Re: half_fast]
#541635
12/24/04 11:01 PM
Why wouldnt you? I'd say, if properly welded, it would be stronger than a factory round tube drive shaft. You make it out of 1/4" square tube. It's beefy as hell.
Only bad part is the vibrations and clanking you get. I can spin mine up to about 35 MPH before it started to vibe out of control.
[Re: Adam F]
#541636
12/25/04 03:20 AM
Yeah the one on my 87 is pretty noisy, but I only use it in 4WD on the trail anyhow.
