FLYWHEEL INTERCHANGE #541987 12/23/04 05:10 AM
TATER Offline OP
Will a 84 22R flywheel fit a 94 22RE ? I thinking It will but I'm wondering about any strange offset of the clutch surface vs. the crank mount.
Re: FLYWHEEL INTERCHANGE [Re: TATER] #541988 12/23/04 08:32 AM
kyle-22r Offline
should be the same
'91 4x4 shortbed
22R-E, W56, the dd!
Re: FLYWHEEL INTERCHANGE [Re: kyle-22r] #541989 12/23/04 04:32 PM
TATER Offline OP
Cool. It looks like I get to spend another holiday weekend working on the daily driver.
Re: FLYWHEEL INTERCHANGE [Re: kyle-22r] #541990 12/23/04 10:35 PM
jasonmt Offline
The flywheel will fit but you will have to use the smaller (91-) 8 7/8" disk and pressure plate as well. 92+ 22RE's use the larger 9 5/16" flywheel, clutch and pressure plate.
Re: FLYWHEEL INTERCHANGE [Re: jasonmt] #541991 12/27/04 05:01 AM
TATER Offline OP
Thanks, thats good info.
Re: FLYWHEEL INTERCHANGE [Re: jasonmt] #541992 12/27/04 05:09 AM
kyle-22r Offline
you know, i should've thought about that when getting a new flywheel...but then again, i'm going to be running an L52 transmission and i dont need to be loading it up any more than a stock clutch <img src="/forums/images/graemlins/lol.gif" alt="" />
'91 4x4 shortbed
22R-E, W56, the dd!
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6078 MB (Peak: 0.6763 MB) Data Comp: Off Server Time: 2026-06-09 23:09:35 UTC
