Thermostat location on 2000 4Runner Ltd
#542977
12/27/04 04:33 PM
Greetings. I have 59k on my 2000 4Runner Ltd, and I'd like to change the thermostat on my next annual coolant flush. Could someone please tell me if the thermostat is connected to the upper or lower radiator hose? I had a '90 Integra, and the thermostat was connected to the lower radiator hose. Thank you.
Re: Thermostat location on 2000 4Runner Ltd
[Re: wquon]
#542978
12/27/04 04:45 PM
It's located on Uper house
[Re: Bratik]
#542979
12/28/04 12:55 AM
Are you sure it's the upper hose on the 5vz? I could have sworn it was the lower hose off the radiator, which enters the engine about mid-height on the driver's side.
Milan _ _ _ _ _ _ __ _ _ _ _ _ _ Support our troops!
'98 4R Limited '82 Toy 4.3 TBI sold
[Re: FattyCBR]
#542980
12/28/04 03:15 PM
The thermostat located on top of the engine, top house that goes from a top of the radiator to the engine block, very easy to replace. I just had timing belt, water pump and thermostat replaced last month. Tokk me about 3-4 hours
[Re: FattyCBR]
#542981
12/28/04 03:16 PM
Are you sure it's the upper hose on the 5vz? I could have sworn it was the lower hose off the radiator, which enters the engine about mid-height on the driver's side. The house you're talking about enters water pump.
[Re: Bratik]
#542982
12/28/04 04:26 PM
Thanks a lot, guys. I will tackle it this weekend.
[Re: Bratik]
#542983
12/29/04 03:40 AM
Here's a pic showing the thermostat located in the middle of the engine feeding the lower hose. ![[Linked Image]](http://img.photobucket.com/albums/v223/fattycbr/Thermo.jpg) The thermostat located on top of the engine, top house that goes from a top of the radiator to the engine block, very easy to replace. I just had timing belt, water pump and thermostat replaced last month. Tokk me about 3-4 hours
