Welding & Electronics
#543008
12/27/04 06:41 PM
I have to weld some reinforcement on a back frame that's rusting out. I don't want to smoke the electronics on my 2.6mpfi in the process with my arc welder. Any tips on isolating the electrical system so I still have a working vehicle when I'm done or is it a non-issue if I keep the ground close to the site of the welding?
'89 P'up, 2.6 I-Tec, 488,000 miles and done... gone to the great beyond
Re: Welding & Electronics
[Re: RT1]
#543009
12/27/04 07:30 PM
Isuzu Moderator
Pull the negative cable off the battery and as you said, keep the ground lead close to where you are welding. If you are still worried, disconnect the ECU.
Good Luck, Michael
[Re: mlclark]
#543010
12/27/04 08:36 PM
Good Luck, Michael Perfect advise!
1995 Trooper LS auto 3.2 DOHC /w SOHC intake 1989 Trooper 2.6 auto 1989 I-Mark RS DOHC 1.6 1991 Stylus XS DOHC 1.8
[Re: mlclark]
#543011
01/04/05 12:23 AM
Thanks. I figured it was that easy, but never hurts to make sure.
[Re: RT1]
#543012
01/04/05 02:15 AM
I never disconnect my battery or anything, I probably should but IÆve never had a problem. I wouldnÆt worry about it.
PHP: 7.4.33 Page Time: 8.801s Queries: 15 (0.004s) Memory: 0.6035 MB (Peak: 0.6676 MB) Data Comp: Off Server Time: 2026-06-10 01:38:02 UTCValid HTML 5 and Valid CSS
