My T is sputtering?? help??
#543712
12/29/04 01:46 AM
I have been doing a lot of driving in the snow at our farm the last week for basic chores and I am having trouble with it. When i hit the gas it seems to only have about half my power. IT sounds like it is missing really bad. I just had a new ignition and plugs about a year ago so I hope it's not that. One thing I might add is that I did let the tank go almost empty right before it got bad. I have ran her low before but it took about 20+ gallons. It has never taken that much, so i figured I ran it took low and it sucked the dirt or grime off the bottom. BEFORE it wasn't to bad i put some dry gas into it but that didnt help. I then put some injector cleaner in next, still no luck. ANy suggestions or help? If you have any ideas please post. It acts like its not getting fuel...never happened before, and it's ironic that it happened when I ran it empty...
Todd
95 4x4 ext cAB t100-
Re: My T is sputtering?? help??
[Re: banshee4785]
#543713
12/29/04 02:07 AM
i've run way lower than 20 gallons. i've actually run my empty.
Scott Landon 1995 T100 - total buildup underway 1988 4Runner (22RE, W56) - new DD 2005 Dodge CTD 4x4 - Tow Beast 1990 Spec Miata 2010 GT3 2013 E92 M3
[Re: banshee4785]
#543714
12/29/04 05:33 AM
I had this problem about a month ago replaced the fuel filter and it was all better.
#543715
12/29/04 07:30 AM
Just had the similar occur on the wifey's 4rnr... Same cure. I cut it open, just to see what it looked like -<img src="/forums/images/graemlins/barf.gif" alt="" />
4xGeek (Chris) '97 T-100 4wd sr5-suto, 3" BL, 1.5" BJ spacers, 35" ProComp AT's, 4.88's, Bilsteins x 6, etc... No longer stuck in SoCal!!
[Re: banshee4785]
#543716
12/29/04 03:08 PM
You could also look at the ignition wires or coils. What do you mean by "new ignition and plugs"?
1995 T100 SR5 XCab 2WD Auto
[Re: surlynkid]
#543717
12/29/04 03:12 PM
The manual for my '98 lists a 24 gallon tank. I can confirm that tank size because that is exactly how much it took to fill it up when I ran the tank dry once. <img src="/forums/images/graemlins/frown.gif" alt="" /> Actually, it only filled up to 23.98 or something like that... but close enough!
EDIT: Just so I'm contributing something, I'll back up previous comments and suggest a new fuel filter. Its an amazing difference.
1998 Toyota T100 SR5 ExtraCab 4WD
