Page 1 of 6 1 2 3 4 5 6
Mitsubishi 4x4 FAQ's #543760 12/29/04 04:46 AM
pmontero Offline OP
Hi Phil/Ray,
I made a stab at a FAQ document that we might want to edit and then make sticky at the top of the forum. It links to the Archives. I used a format similar to another forum I frequent for my Toyota Land Cruiser. Just thought it might cut down on people asking the same questions over and over again. It needs more data though.
Welcome to the 4x4Wire Mitsubishi Technical Forum!
Below is a list of Frequently Asked Questions that link to our Mitsubishi Technical Archive. If you don't see your question here, go first to the Mitsubishi Archive forum and search. If you don't find the answer, feel free to post a question on the technical forum.
If you choose to skip this FAQ and the Archive and ask a basic question on the Technical Forum, you will most likely get a negative response! Please search first!
Thank you for your patience and welcome to our forum! We hope you will enjoy the community up here as much as we do!
Montie's Top Ten
1. What tires will fit on my Montero?
Tire Size
Tire selection
Tire Brands
What Tires will Fit on Factory rims?
2. What lifts are available for my truck?
Body lift Do's and Don'ts
Trim bumpstops
Air Lift/Air Bags
Torsion Bars Demystified
Coil Springs: Which are best?
3. What shocks are the best for my Montero?
<<what happened to all of the posts critiquing shock brand, etc.? I can't find this anymore on any of the forums?>>
4. Are there any aftermarket bullbars for my truck?
<<don't we have a post on Don's bumpers?>>
5. How about lockers for my Montero?
<<links here>>
6. My Montero won't start. Any ideas?
Gen I No Start: Inhibitor Switch
Gen II No Start
7. What years were the Montero's made?
Montero Designations
8. What is a bouncy seat and where do I get one?
bouncy/suspension seats
9. What oil should I use in My Montero's engine, tranny, differentials?
Synthetic vs. Mineral based oils
Differential Lube
Manual Transmission lubricant
Auto Transmission Lubricant
10. Does anyone know the part number for an xxx ?
Specialized Part Number Repository
Re: Mitsubishi 4x4 Frequently Asked Questions for New Members [Re: pmontero] #543761 12/29/04 04:57 AM
Monty Offline
That's a great start! The only thing it need IMO is carb info <img src="/forums/images/graemlins/scared.gif" alt="" />
edit: oh some Recovery stuff to. Winch, straps, snatch blocks etc...
1989 Raider V6/MT
2005 Jeep Liberty CRD Turbo Diesel
Re: Mitsubishi 4x4 Frequently Asked Questions for New Members [Re: Monty] #543762 12/29/04 05:00 AM
LandRaider Offline
GJ Powell!!
Re: Mitsubishi 4x4 Frequently Asked Questions for New Members [Re: pmontero] #543763 12/29/04 05:23 AM
87Montero Offline
Very good Idea... we almost need one for the turbo projects... I don't know how many repeat questions I have asked and then found it was asked earlier... its pretty hard digging through these large threads. I know people are always interested in the turbo swap.. if there is anything I can do to help, I would be happy to.
Brendan
Re: Mitsubishi 4x4 Frequently Asked Questions for New Members [Re: pmontero] #543764 12/29/04 06:09 AM
DaphneD Offline
Mitsubishi 3.0L V6 SOHC and GenI Montero/Raider FAQ:
Valve Cover Gaskets
Q: Why are my vlave covers leaking?
A1: Possibly because the blowby ports (one of those being the PCV valve) have become clogged allowing a buildup of pressure undereath the valve covers eventually expelling the pressure through the seal created by the valve cover gasket. Oil will be expelled with the pressure release.
A2: Age.
A3: If your vehicle has recently experienced an overheat condition, it can harden the valve cover gaskets to the point where they no longer adequately seal.
A4: The valve cover bolts are too tight
A5: The valve cover bolts are too loose.
Q: How easy/difficult is it to change my valve cover gaskets?
A: Remove the ignition coil bracket. Remove the intake plenum. 2 bolts of varying length hold each valve cover down; remove them and work the valve covers until they are removed. Scrape out the old valve cover gaskets.
Place high-temp gasket maker at the elbows for the half-circle cutout at each end to seal the gasket and install the new gasket. Tighten the valve cover bolts to 6-7ft-lbs (8-10Nm). Installation is the reverse of disassembly. Make sure to replace the intake plenum gasket as well.
While you're at it: Replace/clean the PCV valve, clean the baffles of your valve covers, clean out your intake plenum.
Links:
Huge oil leak (06/21/04)
90 V6 Valve cover gasket leaking (09/08/03)
Valve cover gasket question (12/16/02)
Plenum Removal (06/04/04)
PCV valve
Q: Where is the PCV valve located?
A: The PCV valve is located on the driver's side valve cover underneath the intake plenum.
Q: How easy/difficult is it to change the PCV valve?
A: On most early 3.0L engines, the intake plenum will have to be removed in order to get to the PCV valve. Some models without EGR systems make the PCV vavle more accessible and possible to change without removing the plenum. Replace the PCV hose and the hose on the passenger's side vavle cover while you're at it. You will also have to replace the gasket for the intake plenum if it is removed.
Q: Can I reuse the PCV valve?
A: YES. The PCV valve on this vehicle is very durable and can easily be salvaged with a few spritzes of carb cleaner.
While you're at it: Clean your valve cover baffles, replace your valve cover gaskets, clean your intake plenum.
Links:
Wheres the PCV valve? (12/26/04)
PCV Valve Question (02/29/04)
PCV Valve...Removal trouble!! (01/27/03)
Thermostat
Q: Where is the thermostat located?
A: Follow the upper radiator hose back to the nozzle on the intake manifold. The thermostat is located under the nozzle.
Q: How easy/difficult is it to replace the thermostat?
A: Remove the 3 bolts for the ignition coil bracket and set it off to the side. Disconnect any crowding wires. Remove the upper hose from the nozzle. Remove the 2 bolts for the upper hose nozzle and pull it off (you may have to pull hard). The thermostat is plainly visible once the nozzle has been removed. Pry out the old thermostat and scrape off the old gasket with a razor. Install the new gasket and thermostat. The thermostat must be installed correctly to insure proper operation. Draw an imaginary line across the verticle supports on the thermostat. This line should parallel the front of the vehicle, i.e. the imaginary line should extend perpendicular to either side of the vehicle. Due to the offset design of the thermostat and the thermostat block, it is difficult to install the thermostat in the wrong postion.
While you're at it: Replace the U-shaped bypass hose on the thermostat block.
Q: At what temperature does the thermostat operate?
A: The stock thermostat will start opening at 190?(88?C) and will fully open at 212?F (100?C).
Links:
Replacing Thermostat in an 89 LS....where and how? (12/28/04)
Automatic Free-Wheeling Hubs
Q: My auto hubs lock/unlock when they're not supposed to. What can I do about this?
A: GET A SET OF AISIN or SUPERWINCH or WARN MANUAL LOCKING HUBS! Preference is in that order.
Q: Where can I find Aisin manual locking hubs?
A: Junkyards. Look at model years from '88 and prior.
Q: Why is preference given to Aisin manuals?
A: Simplicity. Durability. Reliability. Ease of service.
Rough Idle
Q: Why is my idle rough?
A1: Most likely it is because your Idle Air Control (IAC; read also Idle Speed Control or ISC) servo is dirty.
A2: You have a vacuum leak.
A3: Your EGR system (if equipped) is not operating properly.
A4: The wiring harness for the Airflow Sensor is disconnected (reconnect the wiring harness).
Q: Where is the IAC/ISC located?
A: The IAC/ISC is located on the front of the throttle body, to the bottom right, and has a wiring harness connected to it.
Q: How easy/difficult is it to clean the IAC/ISC?
A: Disconnect the negative battery terminal. Remove the connector for the IAC/ISC. Remove the 2 bolts that hold it in. Wiggle it free. Clean the IAC/ISC with a clean shop towel and a small spritz of carb cleaner if necessary. Do the same for the mating port on the throttle body. Be sure not to get any cleaners deep inside the throttle body or on any gasket surfaces. Replace the IAC/ISC.
Q: What are the possible sources of a vacuum leak?
A1: Vacuum lines for the Emissions Control System.
A2: Breech of the ducting between the airbox and the throttle body.
A3: Bad gasket seal between throttle body and intake plenum.
A4: Bad gasket seal between the intake plenum and intake manifold.
A5: Bad gasket seal between the intake manifold and cylinder heads.
A6: Bad gasket seal between EGR (if equipped) valve and/or pipe and the intake plenum and/or exhaust manifold.
Engine Hesitation
Q: My engine hesitates when I step on the gas. What is causing this problem?
A1: Your IAC/ISC is dirty.
A1: You have a clogged fuel filter.
A2: You have dirty fuel injectors and/or intake valves.
A3: Your Fuel Pump and/or Fuel Pump Relay switch are malfunctioning
A4: Your EGR system (if equipped) is not functioning properly.
Automatic Transmission
Q: My A/T will not downshift or downshifts very late in the gear cycle. Why is this?
A: There is a problem with your Throttle Control Cable (read also Detent or Kickdown cable). The cable has most likely rusted enough to prevent easy movement through the sleeve.
Q: What/where is my Throttle Control Cable?
A: The throttle control cable helps to control shift points depending on the position of the throttle blade. It is located on the top of the throttle cam. The cable itself runs across the top of the intake plenum, curves down and disappears underneath the driver's side footwell, and connects to the valve body on your A/T underneath the vehicle.
Q: How easy/difficult is it to replace the Throttle Control Cable?
A: Replacing the Throttle Control Cable is generally beyond most people's experience level. It involves dropping a valve body inside A/T oil pan. Find a good transmission shop that you trust, bring them the new cable, and ask them to install it. Generally, this operation costs ~$150. Ask for the old cable to make sure the work has been done. Drive the vehicle to make sure the work has been done correctly.
Q: Can I adjust the shift points from the Throttle Control Cable and if so, how do I go about doing so?
A: Yes, but do so using caution; the Throttle Control Cable controls the actuation of particular valves in the valve body and maladjustment can cause other problems. Using the 2 14mm bolts on the bracket located on the top of the intake plenum just behind the throttle cam, you can adjust the tension on the Throttle Control Cable. Adjust the cable until shift points are smooth and predictable. Retighten the 2 14mm bolts in that position.
While you're at it: Drip a few drops of ATF down the Throttle Control Cable.
Q: My A/T Temp light comes on while I'm driving. Why is this?
A1: YOUR AUTOMATIC TRANSMISSION IS OVERHEATING. DO NOT DRIVE THE TRUCK WITH THIS LIGHT ON. THERE ARE SPECIFIC INSTRUCTIONS INSIDE THE VEHICLE ON WHAT TO DO IF THIS LIGHT ILLUMINATES. FOLLOW THEM OR RISK MAJOR DAMAGE TO YOUR TRANSMISSION!
A2: Your ATF level is too low.
A3: Your ATF level is too high.
A4: Your A/T filter is clogged.
A5: Your A/T oil cooler is obstructed or not functioning properly.
Q: What can I do to keep my A/T from overheating?
A1: Make sure the A/T oil cooler on the front of your vehicle is not blocked or caked with debris. Also, check to make sure none of the cooler lines running from the transmission to the oil cooler are bent or kinked.
A2: Change your transmission filter. It is located on the valve body in the oil pan under the transmission. You'll have to drop the large crossmember that supports the A/T and the shifter linkage in order to access the pan. If this is beyond your mechanical abilities, have a shop perform the operation for you.
A3: Drain and refill your ATF with a high-quality DexronIII at least every 20,000mi.
A4: Make sure your ATF level is correct. Too much or too little ATF can cause your A/T to overheat.
Q: How hot is my ATF when the A/T Temp light comes on?
A: The A/T temperature sensor will actuate at ~302?F (~150?C).
Q: My A/T Temp light comes on when I start the car and stays on. Why is this?
A: The A/T Temp sensor is broken. Replace the A/T Temp sensor.
Q: How do I drain and fill the A/T?
A: Briefly drive the truck around the block to allow the ATF to warm up. Open up the drain plug on the bottom of the pan and let the ATF drain out. Replace with a quality DexronIII ATF. With the truck running and your foot on the brake, shift through all gears to fill up the torque converter. Put the shifter in P and recheck the ATF level on the dipstick. Do this several times. The ATF level measured on the dipstick should never get above the "HOT" upper limit. If this happens, the A/T has been overfilled. Drain off some ATF in order to get the ATF to the proper level.
Q: How many quarts of ATF does my A/T take?
A: A drain and fill will require ~3-3.5qts. The entire A/T has a capacity for 7.5qts of ATF.
Oil & Oil Pressure
Q: I'm doing an oil change. How many quarts of oil does my engine take?
A: ~4.5qts on vehicles without an oil cooler. ~5qts on vehicles with an oil cooler.
Q: What items do I need for an oil change?
A: 5qts of oil, a high-quality oil filter, a gasket/crush ring for the oil pan drain plug, and a drain pan for the old oil.
Q: What kind of oil should I put in my engine?
A: Most SAE rated oils are acceptable. 10W-30 is the most common used.
Q: What kind of filter should I use when I change my oil?
A: Use a high quality oil filter. NAPA Gold filters and Mitsubishi OE filters are preferred, but others brands are available.
Q: The needle on my oil pressure gauge barely moves. Why is this?
A1: The oil pressure sending unit has gone bad.
A2: You have low oil pressure.
Q: How easy/difficult is it to fix the Oil Pressure Sending Unit?
A: The Oil Pressure Sending Unit is located on the front of the oil filter bracket. It is a small cylindrical metal object with a single wire lead connected to it. Disconnect the wire and unscrew the unit. Replace with a new Oil Pressure Sending Unit (available most anywhere). Reconnect the wire lead. If the the oil pressure still does not register on the guage then you may have more serious problems than can be solved in FAQ.
Q: What kind of oil pressure should I be getting?
A: The stock electronic gauge setup should display ~10psi/1000rpm. Expect higher readings at cold startup and lower readings at hot idle. At highway speeds, the gauge should be reading ~30psi.
Q: Is the stock Oil Pressure gauge accurate?
A: No, not really. It basically lets you know whether you still have oil pressure or not and is prone to failure.
Tire Size
Q: What size tires can I fit on my GenI Montero/Raider?
A: 31" up to 33" tires fit easily on stock 15x8" rims with little or no modifications. 32"-33" tire sizes may require some trimming of the bumper ends and possibly a moderate suspension lift and/or body lift.
Suspension
Q: How can I raise the suspension on my GenI Montero/Raider?
A: The easiest way is to crank the torsion bars which support the front suspension. A rear lift can be accomplished with add-a-leaf springs or different coil springs depending on suspension type.
Q: How do I crank my torsion bars?
A: Find the rear anchor of the torsion bar. There is a bolt running through each anchor. Place a 17mm box end wrench on the top nut of each anchor bolt and tighten the bolts until the desired lift is achieved.
Q: Is a torsion bar crank really that easy?
A: Yes and no. Yes, it's easy to do, but you'll need a front-end alignment after you do it. Most standard alignment shops will not service a suspension lifted vehicle because it's beyond their capability. Look for a frame alignment shop in the Yellow Pages. Be prepared to open your checkbook.
Q: I cranked my torsion bars and now it rides really rough. Why is this?
A: You cranked the torsion bars until the upper control arm is resting on it's bump stops. Trim the bump stops about half way and it should remedy the problem.
Re: Mitsubishi 4x4 Frequently Asked Questions for New Members [Re: pmontero] #543765 12/29/04 07:51 AM
Guys, this thread is awesome!
For a newbie (like me), this is the perfect place to start.
Thank you.
-Dan
Re: Mitsubishi 4x4 Frequently Asked Questions for New Members #543766 12/29/04 08:14 AM
DaphneD Offline
Common automotive acronyms used in these forums:
A/C - Air Conditioner/conditioning
A/T - Automatic Transmission
ABS - Anti-lock Braking System
ARB - Anthony Robert Brown; Pneumatic differential locker; Common manuafacturer of off-road accessories for our vehicles based in Austrailia.
ATDC - After Top Dead Center (retarded timing)
ATF - Automatic Transmission Fluid
BTDC - Before Top Dead Center (advanced timing)
BJ - Ball joint or Birfield Joint (a type of CV joint)
BSPT - British Standard Pipe Thread
C/C or ECC - Cruise Control or Electronic Cruise Control
CFM - Cubic Feet per Minute (airflow measure)
CV Axle/Joint - Constant Velocity Axle/Joint
DOHC - Dual OverHead Cams
DOJ - Double Offset Joint (a type of CV joint)
ECM - Electronic Control Module or Engine Control Module, i.e. the computer
ECS - Emissions Control System
ECU - Electronic Control Unit or Engine Control Unit, i.e. the computer
EFI - Electronic Fuel Injection
EGR - Exhaust Gas Recirculation valve/pipe/system, etc.
FBC - Feed Back Carburetor
FI - Fuel Injection
FSM - Factory Service Manual
GenI, GenII, Gen2.5, GenIII - Model generations
HLA - Hydraulic Lash Adjusters
HP - HorsePower
IAC - Idle Air Control servo or Stepper Motor (see also ISC)
IFS - Independent Front Suspension (there is no rear IFS)
IPS - Idle Position Switch, often located in the ISC or TPS
IRS - Independent Rear Suspension
ISC - Idle Speed Control servo or Stepper Motor (see also IAC)
LCA - Lower Control Arm
LSD - Limited Slip Differential
LWB - Long WheelBase, i.e. the 4dr model
MAF - Mass Air Flow
MAP - Manifold Absolute Pressure
MPI - Multi-Port Injection
MPT - Metric Pipe Thread
M/T - Manual Tansmission
NPT - National Pipe Thread
OBD I/II - On-Board Diagnostics
PCV - Positive Crankcase Ventilation
P/L or PDL - Power Door Locks
P/S - Power Steering
P/W - Power Windows
SAS - Straight Axle Swap
SMPI - Sequential Multi-Port Injection
SOA - Spring Over Axle
SOHC - Single OverHead Cam
SWB - Short WheelBase, i.e. the 2dr model
TB - Throttle Body
TBI - Throttle Body Injection
TDC - Top Dead Center
TPS - Throttle Position Sensor
TQ - Torque
UCA - Upper Control Arm
VLA - Valve Lash Adjusters
WOT - Wide Open Throttle
Other lingo:
Cat = Catalytic Converter
Diff = Differential
Dizzy = Distributor
KISS = Keep It Simple Stupid
Oz = Australia, the land down-under. <img src="/forums/images/graemlins/wink.gif" alt="" />
Speedo = Speedometer, not swimsuit
T-case or X-case = Transfer Case
Tech = Mitsubish SUV&Tech Forum. Tech IS NOT Talk!
Talk = Mitsubishi Talk Forum, i.e. bla bla bla
WAG = Wild <img src="/forums/images/graemlins/butwiggle.gif" alt="" /> Guess
Clubs & Associations:
ILFWDA - Illinois Four Wheel Drive Association
MFWDCNA - Mitsubishi Four Wheel Drive Club of North America
MM4x4 - Midwest Mitsubishi 4x4
Re: Mitsubishi 4x4 Frequently Asked Questions for New Members [Re: pmontero] #543767 12/29/04 08:41 AM
Big Blue Offline
engine stuff
engine start-up and break in.
This should also be archived!!!!!!!:D <img src="/forums/images/graemlins/smile.gif" alt="" />
Kary
1987 Mitsubishi Pajero "Modified"
The other original Mitsu brother
Northwest Trailmaster
Re: Mitsubishi 4x4 Frequently Asked Questions for New Members [Re: Big Blue] #543768 12/29/04 09:27 AM
DaphneD Offline
So should this (Understanding your Gen I Speedometer)
and this(Replacing a Gen I v6 distributor)
and this(Sway-Away PowerBarz Installation)
Re: Mitsubishi 4x4 Frequently Asked Questions for New Members [Re: DaphneD] #543769 12/29/04 03:43 PM
pmontero Offline OP
Wow, I'm really glad to see folks jumping in here! Dougb, that is a nice piece of work you put in! Thanks Monty and 87Montero for the suggestions on categories. Kary, thanks for the engine break-in link and I think you're right on with the archive comment!
We need to get Phil and Ray's input on how to organize this but my thought is that we need to store most of the data in the Archive to encourage people to use it. Maybe we put FAQs for each category in the archive and have links to them from the technical forum? So, the FAQ main document in the technical forum has main links like, "3.0 V6 issues" or "2.6 carb issues" or "Turbocharging a 2.6" or something like that. Any input on the categories other than what has already been suggested? I like "Engine not starting" as one and then have links to engines, troubleshooting steps, etc.
We have a ton of great information up here that has already been recorded. Maybe what we're doing here is putting a nice "front end" on it that makes it easy for people to get started finding what they are looking for?
Thanks,
Powell
'87 Montero Diesel
'98 Porsche Boxster Electric
and more...
Greasology
NotPetroleum
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6690 MB (Peak: 0.8558 MB) Data Comp: Off Server Time: 2026-06-01 18:15:06 UTC
