Page 3 of 6 1 2 3 4 5 6
Re: Mitsubishi 4x4 Frequently Asked Questions for New Members [Re: DaphneD] #543780 12/29/04 09:55 PM
I took Doug's list and added a couple in [color:"red"] red [/color] and made the above noted [color:"red"] corrections [/color]
A/C - Air Conditioner/conditioning
A/T - Automatic Transmission
ABS - Anti-lock Braking System
ARB - Anthony Robert Brown; Pneumatic differential locker; Common manuafacturer of off-road accessories for our vehicles based in Austrailia.
ATDC - After Top Dead Center (retarded timing)
ATF - Automatic Transmission Fluid
BHP - [color:"red"]Brake [/color] HorsePower
[color:"red"] Birfield Joint - a kind of cv joint [/color]
BTDC - Before Top Dead Center (advanced timing)
BJ - BALL JOINT
CFM - Cubic Feet per Minute (airflow measure)
CV Axle/Joint - Constant Velocity Axle/Joint
DOHC - Dual OverHead Cams
DOJ - Double Offset Joint - [color:"red"] another cv joint [/color]
ECS - Emissions Control System
ECU - Electronic Control Unit or Engine Control Unit, i.e. the computer
EFI - Electronic Fuel Injection
EGR - Exhaust Gas Recirculation valve/pipe/system, etc.
FBC - Feed Back Carburetor
FI - Fuel Injection
GenI, GenII, Gen2.5, GenIII - Model generations
HP - HorsePower
IAC - Idle Air Control servo or Stepper Motor (see also ISC)
[color:"red"] IPS - idle position switch often in the ISC or TPS [/color]
ISC - Idle Speed Control servo or Stepper Motor (see also IAC)
LCA - Lower Control Arm
LSD - Limited Slip Differential
LWB - Long WheelBase, i.e. the 4dr model
MPI - Multi-Port Injection
M/T - Manual Tansmission
OBD I/II - On-Board Diagnostics
P/L or PDL - Power Door Locks
P/S - Power Steering
P/W - Power Windows
SOHC - Single OverHead Cam
SWB - Short WheelBase, i.e. the 2dr model
TB - Throttle Body
TBI - Throttle Body Injection
TDC - Top Dead Center
TPS - Throttle Position Sensor
TQ - Torque
UCA - Upper Control Arm
Other lingo:
Cat = Catalytic Converter
Diff = Differential
Dizzy = Distributor
Oz = Australia, the land down-under.
Speedo = Speedometer, not swimsuit
T-case or X-case = Transfer Case
Tech = Mitsubish SUV&Tech Forum. Tech IS NOT Talk!
Talk = Mitsubishi Talk Forum, i.e. bla bla bla
Re: Mitsubishi 4x4 Frequently Asked Questions for New Members [Re: PartyTruck] #543781 12/29/04 10:02 PM
DaphneD Offline
BHP - British HorsePower
Sorry, been smokin' that crack again. Edited. <img src="/forums/images/graemlins/wink.gif" alt="" />
I admit that my information is neither complete nor professionally acquired. It would be helpful to contribute something to a worthwhile thread other than useless critisizm which can be done in PM format. Thanks.
EDIT: Thank you Eddy. Changes made.
Re: Mitsubishi 4x4 Frequently Asked Questions for New Members [Re: DaphneD] #543782 12/29/04 10:37 PM
MarkG Offline
At one time someone suggested adding "archive this" to a thread that needed moved to the archive. It allowed the moderators to do a search (I said that word) to locate the threads to archive.
How about also using "faq this" for items that could be placed in the FAQ?
Re: Mitsubishi 4x4 Frequently Asked Questions for New Members [Re: Monty] #543783 12/29/04 11:26 PM
LRJ4x4 Offline
The Carburetor! for the lucky owners of the Mikuni Feedback Carburetor <img src="/forums/images/graemlins/pfft.gif" alt="" /> The first thing you need before you start your carb quest is the Factory Manual for your specific year. Otherwise you might as well beat yourself with a baseball bat in the dark. It's less painful and does not require as much brainpower. If that does not scare you then besides basic tools you will need a hand vacuum pump and a nice digital multimeter. I am by no means the expert on the carb. I learned most of this from other forum members and by RTFM ( reading the friggen manual )
The Major issues.
1. The Depression Chamber, it's a UFO shaped vacuum device that opens the 2nd barrel on the carb. When they go bad they don't hold vacuum. The 2nd barrel does not open resulting in a very sluggish performance.
To test, remove air cleaner, remove vac line to depression chamber and attach a vacuum hand pump. Open the primary barrel by either having a friend press the gas pedal or by hand on carb ( 2nd barrel will only open when first barrel is open ) Apply vacuum and watch for 2nd barrel to open. It should hold vacuum and not leak down. If it does not open or leaks down you need a new depression chamber. Test procedure in manual.
2. The Bowl Vent Valve. Your carb is heated by engine coolant. When you turn the engine off the gas in the bowl of the carb produces gas fumes. These fumes exit thru the bowl vent valve and collect in the canister next to the passenger side front head light. If the bowl vent valve is not working the fumes collect in the intake manifold and cause the engine to flood and hard start. The bowl vent valve does not come in a standard carb rebuild kit and there lies the problem. The Mukuni is a complex carb and needs fixed by someone with experience. DonÆt think you can crack open a Mikuni and slap a rebuild kit to fix all your problems.
3. The Sensors. The feedback carb is controled by the ECU via input from four sensors. Some carb problems are not really carb problems but sensors problems. You have to check the sensors first before you blame the carb. People want to tinker with the fuel-air mixture all the time but it ends up being the O2 sensor <img src="/forums/images/graemlins/smile.gif" alt="" />.
A. Engine Speed Sensor
B. Throttle Position Sensor, AKA TPS
C. Oxygen Sensor, AKA O2 sensor
D. Engine Cooland Temperature sensor.
4. The Maze of Vacuum lines. The vac lines are color coded and you just have to tag them when you remove them. The chart under the hood is OK but nothing is better than tagging them if you have to remove the carb. The vac lines like to crack on the underside where the attach to the nipples. You have to check each and every one for cracks, because a vacuum leak will cause problems. There are two major switches, the Thermo Switch and the Thermo Valve, there plastic and like to crack. The carb comes in a variety of configurations, Federal and California, Federal with High Altitude, California with High Altitude and all over again for either Manual or Automatic tranny. The manual has the test procedures.
5. The Choke. The choke is electric and controlled by the ECU. The test procedure is in the manual.
Do your homework before complaining on the board about your carb. Saying your carb is being strange does not give us much to work with. We need the whole story to give any type of reply that is helpful, or at least get you started in the right direction.
Thats all for now, I have to get back to my paying job.
<img src="/forums/images/graemlins/patriot.gif" alt="" />
Re: Mitsubishi 4x4 Frequently Asked Questions for New Members [Re: LRJ4x4] #543784 12/29/04 11:31 PM
Monty Offline
<img src="/forums/images/graemlins/lol.gif" alt="" />
Thats great info LRJ4x4 <img src="/forums/images/graemlins/kewl.gif" alt="" />
No Mikuni for me tho <img src="/forums/images/graemlins/butwiggle.gif" alt="" />
1989 Raider V6/MT
2005 Jeep Liberty CRD Turbo Diesel
Re: Mitsubishi 4x4 Frequently Asked Questions for New Members [Re: DaphneD] #543785 12/30/04 09:48 AM
52degrees Offline
DougB,
I still see Mitsu cars around with OZ racing stickers on them. I had no clue what everybody was talking about and it is kinda funny. Like walking into a conversation where everybody knows what the topic is so they don't mention it they think you know but you don't so your trying to figure it out but can't because nobody says anything directly relating to what they are really talking about. And then seeing those stickers really threw me.
Clay
KG6VNX
Re: Mitsubishi 4x4 Frequently Asked Questions for New Members [Re: MarkG] #543786 12/30/04 10:43 AM
PartyTruck Offline
I'm sorry Doug but I couldn't resist. Hope you can forgive.
1987 SWB Pajero 2.5 TDI on 31" rubber waiting for a hip replacement and bigger shoes
Re: Mitsubishi 4x4 Frequently Asked Questions for New Members [Re: PartyTruck] #543787 12/31/04 05:56 AM
dadrab Offline
Excellent job, y'all.
Even if this doesn't get stickied, I've put it in my favorites.
with awesome audio.
Re: Mitsubishi 4x4 Frequently Asked Questions for New Members [Re: 52degrees] #543788 12/31/04 06:32 AM
Big Blue Offline
Clay;
There is also an OZ wheel company that Mitsubishi includes in one of their option packages on the Lancer, and possibly a couple of others. If it a sticker....its not referring to, and has nothing to do with Austraila.
SO, you still may be in the dark. <img src="/forums/images/graemlins/smile.gif" alt="" />
Kary
1987 Mitsubishi Pajero "Modified"
The other original Mitsu brother
Northwest Trailmaster
Re: Mitsubishi 4x4 Frequently Asked Questions for New Members [Re: PartyTruck] #543789 12/31/04 11:13 AM
DaphneD Offline
I forgive. <img src="/forums/images/graemlins/wink.gif" alt="" />
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6504 MB (Peak: 0.7652 MB) Data Comp: Off Server Time: 2026-06-09 10:09:40 UTC
