Page 4 of 6 1 2 3 4 5 6
Re: Mitsubishi 4x4 Frequently Asked Questions for New Members [Re: DaphneD] #543790 12/31/04 06:43 PM
Tag Offline
I have the bouncy seat. I do not have the headlight washers or LSD. But mine is a Raider not a montero. <img src="/forums/images/graemlins/rolleyes.gif" alt="" />
89 2dr 3.0 AT, manual hubs. 33x12.5 MT
gen 2 coils,Cranked front tbars
Dons rocker protection, Front/Rear Bumpers. ARB rear locker, 2" BL, Beefed up skid plates/trailing arms. Gen II uca, 2 Bouncy seats www.youtube.com/TagGeorge
Re: Mitsubishi 4x4 Frequently Asked Questions for New Members [Re: pmontero] #543791 01/01/05 11:51 PM
L
lu0902 Offline
Wow.. <img src="/forums/images/graemlins/kewl.gif" alt="" /> This is great. Keep it coming. I was just about to post a question: But not any more because I found the answer within these posts.
1987 DODGE RAIDER 4X4, 2.6 LITTER, 5 SPEED MANUAL MODS+PARTS:
Re: Mitsubishi 4x4 Frequently Asked Questions for New Members [Re: lu0902] #543792 01/13/05 12:15 AM
DaphneD Offline
GenI Recommended Regular Scheduled Maintenance (as taken from the '89 FSM) with some changes and additions:
Change Engine Oil = 7,500mi (12,000k) or 12mos
*Replace oil pan drain plug gasket at every oil change
Replace Engine Oil Filter = 15,000mi (24,000k) or 12mos
Change ATF = 30,000mi (48,000k)
*Replace ATF oil pan drain plug gasket at every oil change
Check M/T Gear Oil = 30,000mi (48,000k)
Check T-Case Gear Oil = 30,000 (48,000k)
Check Fr Differential Gear Oil = 30,000mi (48,000k)
Check Rr Open Differential Gear Oil = 30,000mi (48,000k)
Change Rr LSD Gear Oil = 30,000 (48,000k)
Replace Brake Fluid = 30,000mi (48,000k) or 2yrs
Change Engine Coolant = 30,000mi (48,000k) or 2yrs
Grease UCA & LCA Ball Joints = 15,000mi (24,000k) or 12mos
Grease UCA shaft = 15,000 (24,000k) or 12mos
Grease Steering Linkage = 15,000mi (24,000k) or 12mos
Grease Propeller Shaft U-Joints = 30,000mi (48,000k) or 2yrs
Repack Fr Wheel Bearings = 30,000mi (48,000k) or 2yrs
Replace Air Filter = 30,000mi (48,000k)
Clean PCV Valve = 80,000mi (128,000k) or 5yrs
Replace Spark Plugs = 30,000mi (48,000k)
Replace Ignition Cables = 60,000mi (96,000k)
Check Distributor Cap = 60,000mi (96,000k) or 5yrs
Check Distributor Rotor = 60,000mi (96,000k) or 5yrs
Replace Drive Belts = 30,000mi (48,000k)
Replace Timing Belt = 60,000mi (96,000k)
Replace 02 Sensor = 80,000mi (128,000k)
Replace Fuel Filter = 50,000mi (80,000k) or 5yrs
Replace Charcoal Canister = 100,000mi (160,000k)
Inspect Fr Disc Brake Pads for wear = 15,000mi (24,000k) or 12mos
Inspect Fr Brake Calipers = 30,000mi (48,000k) or 2yrs
Inspect Rr Drum Brake Shoes for wear = 30,000mi (48,000k) or 2yrs
Inspect Rr Drum Brake Cylinders = 30,000mi (48,000k) or 2yrs
Inspect Brake Hoses = 30,000mi (48,000k) or 2yrs
Re: Mitsubishi 4x4 Frequently Asked Questions for New Members [Re: pmontero] #543793 02/10/05 07:06 PM
DaphneD Offline
3.0L V6 Crank pulley
Q: STOP! Read the answer below before you even ask this question.
A: The crank bolt on ALL Mitsubishi 3.0L V6 engines is a recall item. This is mentioned several times in the archives. Do a search and you will come up with seemingly endless results of people who have had their crank bolt snap and things go haywire. The old bolt was prone to undertorquing and failure. You will need to replace it.
Q: What's that you ask? Do I really have to worry about this?
A: If you have a Mitsubishi 3.0L V6 engine with the old style crank bolt, the answer is yes! It's not a question of will it happen, it's a question of when it will happen! It's a 15min job to fix what will cost you much much more in time and money when it fails while your driving.
Q: But...
A: No buts - FIX IT!
Q: But...
A: But what?! Fix it!
Q: Bu..
A: Fix it!
Re: Mitsubishi 4x4 Frequently Asked Questions for New Members [Re: DaphneD] #543794 03/01/05 02:56 AM
It would also be nice to include some links to the aftermarket suppliers.
Re: Mitsubishi 4x4 Frequently Asked Questions for New Members #543795 03/01/05 04:22 AM
I agree on the aftermarket links. I,ve only had mine for about a week, but i've spent hours upon hours searching. Very few sites even list mitsubishi,and when they do it usually comes up with nothing.
Re: Mitsubishi 4x4 Frequently Asked Questions for New Members #543796 03/01/05 07:27 AM
DaphneD Offline
Did you fix your crank bolt yet?! <img src="/forums/images/graemlins/pfft.gif" alt="" />
Aftermarket vendor links are generally located in the SPNR, also stickied at the top of the page. If you don't find what you're looking for there, click on the link in my sig. <img src="/forums/images/graemlins/wink.gif" alt="" />
'89 Raider 3.0L V6 (6G72) w/ AW372L (A44DL) A/T
"The Millennium Falcon of automobiles"
Re: Mitsubishi 4x4 Frequently Asked Questions for New Members [Re: Tag] #543797 06/12/05 05:04 AM
This is a GREAT website! <img src="/forums/images/graemlins/smile.gif" alt="" />
Another-nice-to-have FAQ category - Recalls.
Provide details like when you got it and quote the document verbatim. Seems I've missed some that I saw in these threads!<img src="/forums/images/graemlins/confused.gif" alt="" />
Re: Mitsubishi 4x4 Frequently Asked Questions for New Members [Re: DaphneD] #543798 08/17/05 08:56 PM
AZOutsider Offline
I knwo this is ancient but its worth reviving... well, to me at least. Where can I find a list like this for my truck? 04 Montero Sport LS.
Any info would be greatly appreciated!
'04 Mitsubishi Montero Sport LS 4x4
3.5l SOHC V6
No locker, no LSD, no nothin' <img src="/forums/images/graemlins/frown.gif" alt="" />
2.5" lift sittin on ProComp 1069 Xtreme Alloys wrapped with 33x12.50X16 Trxus-STS's
Custom front end and sliders
Enough Hella wattage to burn a hole in the sun
Re: Mitsubishi 4x4 Frequently Asked Questions for New Members [Re: AZOutsider] #543799 08/17/05 10:33 PM
Charlie Belew Offline
One place to try is Montero Sport board .
None
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6415 MB (Peak: 0.7467 MB) Data Comp: Off Server Time: 2026-06-20 21:48:18 UTC
