Page 2 of 3 1 2 3
Re: 3.5 motor idea's [Re: OKRED] #544399 12/30/04 01:47 AM
Swapping bodies with all associated wiring harnesses easier? Probably more like swapping one hornets nest for another... but then again, I have pretty limited experience with that. <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: 3.5 motor idea's [Re: off-roader] #544400 12/30/04 02:50 AM
Jamez Offline
Not to derail the conversation, but if a V6 would have trouble fitting inside an SWB, how did the guys with small block V8's get those in there? Seems like the block would be a good bit longer than a 6, but I don't know any details of such a swap.
'87 Raider w/rebuilt 2.6
Weber 32/36
Re: 3.5 motor idea's [Re: Jamez] #544401 12/30/04 03:19 AM
LandRaider Offline
the guys with Small Block v8s moved the radiator support foward, or hacked the firewall out.
OR ran with no water pump and acessories on the front of the motor. <img src="/forums/images/graemlins/smile.gif" alt="" />
HMMM I need to go measure my friends Lt1!! <img src="/forums/images/graemlins/confused.gif" alt="" />
Re: 3.5 motor idea's [Re: LandRaider] #544402 12/30/04 03:27 AM
DaphneD Offline
I would be willing to bet that the engine bay in the GenIIs is smaller than the GenIs... that's just from eyeing it though. The 3.5L and 3.0L blocks seem to share many things in common. That goes across the board through all generations of Montero - many things remain the same throughout.
Re: 3.5 motor idea's [Re: DaphneD] #544403 12/30/04 03:36 AM
LandRaider Offline
As I recall the guy that put the "police Package" 350 with a 700r4 in his Gen2 with the Adapter in the transfer case did not have much problem with the fitment.
Looked like that 350 sat right down in there. We need gen 2 engine bay measurements.
Re: 3.5 motor idea's [Re: LandRaider] #544404 12/30/04 07:18 AM
StockRaider Offline
someone needs to go out and try this, I got access to a Gen1 without engine and just need to find a donor 3.5 with all the "goodies" attached <img src="/forums/images/graemlins/smile.gif" alt="" />
Richard E
1989 Montero - Stock-ish
1983 Honda XL600R
Re: 3.5 motor idea's [Re: LandRaider] #544405 12/30/04 07:30 AM
Big Blue Offline
Curts; If you mean "helix" he cut the hood latch and most of the core support out in the rig. He used hood pins to hold the hood down. <img src="/forums/images/graemlins/barf.gif" alt="" /> <img src="/forums/images/graemlins/barf.gif" alt="" /> <img src="/forums/images/graemlins/confused.gif" alt="" />
Kary
1987 Mitsubishi Pajero "Modified"
The other original Mitsu brother
Northwest Trailmaster
Re: 3.5 motor idea's [Re: StockRaider] #544406 12/30/04 07:47 AM
Carlos (cap510 might be able to help there...) <img src="/forums/images/graemlins/kewl.gif" alt="" /> but it will be coming from CA.
Re: 3.5 motor idea's [Re: off-roader] #544407 12/30/04 10:02 AM
bretwalda Offline
Lemme know what measurements you need (within reason) I seem to be finding myself in the garage quite a bit lately <img src="/forums/images/graemlins/shiner.gif" alt="" />
Draw on this if you need to:
The 3.5 still doesn't use a transfer case with a low range that would be considered good by most here.
Frank is actively pursuing that and has the prototype in his truck. 66% reduction over standard <img src="/forums/images/graemlins/oink.gif" alt="" /> Last I heard they will start a batch very soon.
concreteprinter.com
Re: 3.5 motor idea's [Re: bretwalda] #544408 12/30/04 05:34 PM
lordtrunks Offline
A guy in Aus just finished this 3.5 swap check out the outerlimits4x4 board for more info but he swaped the engine into his 89 SWB. New exhaste manifolds and some other fab had to be done.
89 2 dr turbo diesel
89/88 "Backwoods sas"
Page 2 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6430 MB (Peak: 0.7527 MB) Data Comp: Off Server Time: 2026-06-07 09:05:47 UTC
