3.4 Trooper swap/ Which Alternator will I use? #544669 12/30/04 02:11 AM
Duchauler Offline OP
I have a chance to get a new alt before the 2.8 comes out and the 3.4 goes in so which alt am i going to use, the Camaro alt or the trooper alt?
" A man who does follow his dreams,
might as well be a vegetable"
Burt munro
'95 Montero SR
'01 Aprilia Futura
Re: 3.4 Trooper swap/ Which Alternator will I use? [Re: Duchauler] #544670 12/30/04 04:01 AM
Ed Mc Offline
You'll be using all the accessories off the old 2.8. Which would include the alternator, intake and exhaust, smog pump, power steering pump, A/C compressor (if so equipped), brackets, flywheel, oil filter adapter, etc etc etc.
Couldn't tell you offhand whether the Camaro used the same alternator, I suppose it's possible but my 3.4 had the accessories already stripped off it so couldn't say for sure. Best to just stick with the 2.8 alt (which, BTW, should be exactly the same as one for an S-10 2.8).
If you don't have the swap writeup, send me a P.M. and I'll forward the info to you.
Happy Swapping...........ed
'90 Troop 3.4 LS
'89 Troop RS (Has Valve Issues, needs Counseling)
HI, I'm Ed and I'm a Trooper-holic!
Keep On Troopin'......
PHP: 7.4.33 Page Time: 2.344s Queries: 15 (0.007s) Memory: 0.5871 MB (Peak: 0.6350 MB) Data Comp: Off Server Time: 2026-07-15 08:36:47 UTC
