Help identifying engine mounts.... #546577 01/04/05 01:17 AM
gcinque Offline OP
Happy New Years All!! <img src="/forums/images/graemlins/cheers.gif" alt="" />
I purchased two engine mounts on ebay and I think one of them is not for my truck. By the looks of things the mount the shortcut points to is not for my truck. Before I start taking things apart I was wondering if anyone could confirm this.
http://thumb6.webshots.com/t/18/19/0/65/16/243506516XwMGru_th.jpg
Thank you,
gcinque
03 Tacoma Xtra cab 4cyl 5spd
89 4Runner/Jasper reman 22RE/Auto SOLD
98 Tacoma Xtra cab 4cyl Auto SOLD
Re: Help identifying engine mounts.... [Re: gcinque] #546578 01/04/05 02:26 AM
kewlynx Offline
Doesn't look like it. I take it the bottom piece sticking out is a bolt stud and nut?
You have 4 bolts on each mount that attach it to your frame, then 4 bolts each to the engine. If you pull your skidplate off and look up at each of them, you'll see it.
**ubi apis- ibi salus**
Re: Help identifying engine mounts.... [Re: kewlynx] #546579 01/04/05 05:00 AM
willzrunna96 Offline
not a 22e motor mounr
Re: Help identifying engine mounts.... [Re: kewlynx] #546580 01/04/05 05:21 AM
gcinque Offline OP
I did see the four bolts you mentioned, I didn't have to touch those when I replced the passenger side mount. All I did was unbolt three bolts, lift the engine just enough to slide the rubber piece out and install the new one.
This engine mount looks like it gets bolted either to the frame or the engine with only two bolts. After starring at it for a while I think it's probably (engine mount and the support) one piece that gets bolted to the frame. In my case the support is already welded to the frame, all I need is the rubber piece.
I just wanted to make sure this was not the engine mount for my truck. Now the fun begins trying to return this engine mount and get the correct one sent asap.
[img]http://community.webshots.com/scripts/editPhotos.fcgi?action=showMyPhoto&albumID=233194081&photoID=243896457&security=GLKWhx[/img]
Thanks for your help!
gcinque
Re: Help identifying engine mounts.... [Re: gcinque] #546581 01/04/05 09:55 AM
kewlynx Offline
Sorry, went out to another engine I have with the mounts; on the frame side is 2, not 4 holes. The 4 holes is on the engine side. I also saw a piece of angled metal in your t'nail; 22Rxx mounts don't have ANYTHING sticking out.
Both mounts are opposite and symetrical, if that helps your case. The only thing after that is how you stack up the alternator brackets and stuff on the driver's side.
Good luck; copy/paste from here.
Re: Help identifying engine mounts.... [Re: kewlynx] #546582 01/04/05 05:44 PM
gcinque Offline OP
Thanks guys for the info!!!
Now the fun begins trying to get the ebay seller to send me the right part.
Thanks again!!! <img src="/forums/images/graemlins/kewl.gif" alt="" />
gcinque
PHP: 7.4.33 Page Time: 5.999s Queries: 15 (0.003s) Memory: 0.6112 MB (Peak: 0.6816 MB) Data Comp: Off Server Time: 2026-06-17 08:04:05 UTC
