Rating: 5
Page 4 of 7 1 2 3 4 5 6 7
Re: READ FIRST IF YOU NEED TO CHANGE THE SPARK PLUGS [Re: LiorB] #547259 05/09/10 03:58 PM
Everet Offline
RockAuto.com has several sets to choose from. Also, go to a good independent autoparts store, and they should be able to get some. O'Rielys and AutoZone don't sell them.
The dealership is usually about 30-50% higher in cost.
Tell us what you find.
Re: READ FIRST IF YOU NEED TO CHANGE THE SPARK PLUGS [Re: Everet] #547260 05/10/10 07:28 PM
L
LiorB Offline
Thanks Everet,
The thing is I live in Israel, and all we have here are the dealer's (they are about $48).
What I usually do is order and send it to my brother in law that lives in NY, and he sends it to me (or someone brings it when visiting).
What would you recommend from RockAuto.com's list?
Lior
Re: READ FIRST IF YOU NEED TO CHANGE THE SPARK PLUGS [Re: LiorB] #547261 05/11/10 05:15 AM
londart Offline
just about any auto parts store shouls sell them,at my work we have stocked belden,borg warner and standard motor products and all 3 brands had them in premium or economy sets, i know the o'reilleys here sells borg warner and they have them
Lonnie
Auto Parts Professional
95 sportage sold but not forgotten
Re: READ FIRST IF YOU NEED TO CHANGE THE SPARK PLUGS [Re: londart] #547262 05/11/10 09:58 AM
L
LiorB Offline
Thanks Lonnie,
The problem is not where to get it but which brand to get.
I know the quality of the wires is important, my question is are the more expensive ones twice as good than the chipper ones.
Is it worth to pay $50 or can I just settle with the $16 ones (BOSCH).
Lior
Re: READ FIRST IF YOU NEED TO CHANGE THE SPARK PLUGS [Re: LiorB] #547263 05/11/10 10:53 AM
DamKia Offline
Kia Moderator
Given that the longest cable run is about 15" I would think if you could get the Bosch ones to fit then they would be OK. The cables are covered from the elements anyway so dirt/grime/grease should not be an issue.
Worst case is you waste $15.
Re: READ FIRST IF YOU NEED TO CHANGE THE SPARK PLUGS [Re: DamKia] #547264 05/12/10 05:44 AM
londart Offline
even the economy ones that we sell are good wires and still made by the same company as the premium or at least for the same company, sometimes they are outsourced...the main difference is a 5year 100,000 mile warranty versus a lifetime warranty on the premiums...if your only concern is the $ and not 5 or 10 years down the road go with the economy, they should last at least the 5 years, if not they're covered <img src="/forums/images/graemlins/cheers.gif" alt="" />
Lonnie
Re: READ FIRST IF YOU NEED TO CHANGE THE SPARK PLUGS [Re: londart] #547265 05/12/10 08:13 AM
L
LiorB Offline
I prefer to replace them anyway every 4-5 years so I think I'll go with the BOSCH wires.
Thanks guys
Re: READ FIRST IF YOU NEED TO CHANGE THE SPARK PLUGS [Re: LiorB] #547266 01/07/11 03:15 PM
2002_Sporty Offline
Ok, I just ordered some parts for my Sporty's first tune up from http://www.rockauto.com/.
Looking to improve Miles Per Gallon.
Look over my list and let me know if I'll need anything else. I think I got it all.
*Bosch Platinum +4 Spark Plugs x 4
*Bosch Spark Plug Wire Set, Includes 2 Wires
*FEL-PRO Throttle Body Gasket x 1
*FRAM PCV Valve x 1
*Victor Reinz Valve Cover Gasket x 1
*Antiseize for the spark plug threads.
One more Question: Is the decorative plastic cover over the top of the engine a functional piece of equipment?
I mean; Does it force air over the engine for direct cooling, help make an air bubble over valve cover when fording rivers, or is it just added weight?
2002 4dr Kia Sportage 4X4
Tires:235/75/15, Wheels: Black 15x8 Steel ProComp 2.5" B.S., Hubs:Warn Manual, Lift:3" UPYOURKIA, Trailer Hitch, Cargo Rack, Clinometer.
Re: READ FIRST IF YOU NEED TO CHANGE THE SPARK PLUGS [Re: 2002_Sporty] #547267 01/07/11 05:25 PM
DennisThompson Offline
There is no need to replace your valve cover gasket unless yours is leaking, you just need to remove the center cover to get to the spark plugs, not the valve cover. I would change the fuel filter also unless it has allready been done. The decorative is just that decorative, my 95 does not have one.
Dennis
Re: READ FIRST IF YOU NEED TO CHANGE THE SPARK PLUGS [Re: 2002_Sporty] #547268 01/07/11 06:22 PM
promodmerc Offline
*FRAM PCV Valve x 1
Me personally I would not use BOTCH plugs if my life depended on it. Stick with NGK. I can guarantee in 6 months you'll be replacing those BOTCH plugs.
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.006s) Memory: 0.6447 MB (Peak: 0.7532 MB) Data Comp: Off Server Time: 2026-10-22 12:14:36 UTC
