Rating: 5
Page 7 of 7 1 2 3 4 5 6 7
Re: READ FIRST IF YOU NEED TO CHANGE THE SPARK PLUGS [Re: BAZINGA] #547289 05/03/11 12:51 PM
2002_Sporty Offline
Completed my first spark plug change this past weekend.
Followed the guidlines above and it went smoothly. Thank you for the great post guys.
I also got a chance to clean the throttle body too.
Ended up taking the valve cover off when I found a little oil in cylinder # 4. The leak was quite small and had no puddling, but I was worried and had the gasket on hand, plus I was almost all the way there anyways.
All in all I got to do something I had never done before and with possitive results.
My rig is running a whole lot smoother and is seeing a gain in milage. <img src="/forums/images/graemlins/smile.gif" alt="" />
2002 4dr Kia Sportage 4X4
Tires:235/75/15, Wheels: Black 15x8 Steel ProComp 2.5" B.S., Hubs:Warn Manual, Lift:3" UPYOURKIA, Trailer Hitch, Cargo Rack, Clinometer.
Re: READ FIRST IF YOU NEED TO CHANGE THE SPARK PLUGS [Re: 2002_Sporty] #547290 06/26/12 04:34 PM
Davey Offline
Just done my plugs and valve cover gasket, all 4 plugs were submerged under about 20mm of oil...
Have rotted c.o.p. boots (really?! Think the oil mighta caused that?!), in chasing them up I get 2 part numbers.
NGK 58932 and/or CPB K002 .
Now just gotta find a supplier who charges less than $60 to post it <img src="/forums/images/graemlins/scared.gif" alt="" />
Long a$$ 2000 Sporty, auto, 5.38 gears, TF front locker, 4"+ front lift (Kings +40 springs, 50mm spacers, 1.5" diff drop), TJ 104 rears 3" + 50mm coil spacers, 1.5" body lift, 31/10.5r15's on 15x8 Kings (ET-13), WARN manuals, Smart Bar, spotties
Re: READ FIRST IF YOU NEED TO CHANGE THE SPARK PLUGS [Re: Davey] #547291 04/17/15 09:07 PM
Nukeiridium Offline
I just changed the coil on plug boots and luckily they were about $11 each from OReilly <img src="/forums/images/graemlins/notooth.gif" alt="" /> <img src="/forums/images/graemlins/butwiggle.gif" alt="" />
I hate the valve cover gasket on these Sportages. Always ends up leaking. I used some RTV on that [censored] this time. I know it will be harder to redo later if I have to do it again. Hopefully by the time that gasket goes bad again, the truck will have died from other causes anyway <img src="/forums/images/graemlins/evil.gif" alt="" /> <img src="/forums/images/graemlins/nana.gif" alt="" />
2002 Sportage 4dr 4x4 soon to undergo an Extreme Makeover!
Re: READ FIRST IF YOU NEED TO CHANGE THE SPARK PLUGS [Re: Axe Man] #547292 09/01/15 09:01 PM
10ring Offline
Well...S#!&, I'm in the middle of getting down to the coils and plugs, and disconnected the harness from the IAC to better hose it out with carb cleaner.
What's going to happen when I put it all back together, and how do I fix it?
Re: READ FIRST IF YOU NEED TO CHANGE THE SPARK PLUGS [Re: 10ring] #547293 09/02/15 03:17 AM
10ring Offline
Pics from my progress so far:
http://imgur.com/a/pZxTI
They sold me the wrong gasket. Make sure they give you the one with 3 bolt holes and one small rectangle, not 4 bolt holes.
The connectors on the ignition wiring harness (Kia part # 27310-2Y052) are garbage, and crack and fall apart if you look at them wrong. Unfortunately that looks like something I can't get locally.
http://www.ebay.com/itm/1995-2004-Kia-Sp...fde&vxp=mtr
PHP: 7.4.33 Page Time: 0.016s Queries: 16 (0.013s) Memory: 0.6170 MB (Peak: 0.6983 MB) Data Comp: Off Server Time: 2026-10-21 20:37:50 UTC
