Exhaust routing with 2.5-inch tubing #547727 01/05/05 04:53 AM
W
whitetoy Offline OP
Gotta dumb question here.
Anyone know a good source of 2.5-inch flexible tubing ?
I want to be able to work on the rig while its running (set timing, etc) while in the garage,
and not fill up the garage with fumes.
I'll attach the tubing to the exhaust pipe and route it (maybe 20 feet or so) outside.
Rick
1984 4Runner
Post deleted by little_joe [Re: whitetoy] #547728 01/05/05 05:45 AM
Re: Exhaust routing with 2.5-inch tubing #547729 01/05/05 10:15 PM
W
whitetoy Offline OP
Thanx for the response, Thief.
That hose sounds perfect, but a bit pricier than
I am willing to go, for something used rarely.
Dryer hose, is too big and awkward to attach
to the exhuast, but I may try that anyway.
Thanx for the tip about MCMASTERS
Rick
1984 4Runner
Post deleted by little_joe [Re: whitetoy] #547730 01/06/05 03:40 AM
Re: Exhaust routing with 2.5-inch tubing #547731 01/06/05 03:43 AM
go down to your local car dealership and ask if you can have scraps of the rubber ones they use. Mechanics accidentally leave them on after working on the car then back up and tear them in half. This leaves piles of scraps. I have two 6' sections I got this way.
Re: Exhaust routing with 2.5-inch tubing #547732 01/07/05 10:13 PM
This is the stuff the shops use. $54 is a little pricey but how much is your lungs worth?
http://www.drivewerks.com/catalog/ShopCart/TOOL/POR_TOOL_CAT586_pg11.htm
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.007s) Memory: 0.5990 MB (Peak: 0.6676 MB) Data Comp: Off Server Time: 2026-11-07 17:27:29 UTC
