Re: Axle Ratio #548500 06/11/05 01:20 PM
little_joe Offline
Former Admin
I have to wait until Monday to call the dealer, but someone notified me that as of 2000 or 2001, the traditional gear code is meaningless anyway - everything is B07A.
The gear code is in the 14-digit string above the gear, tranny, trim, paint code, usually starting with an R.
Not sure if this is true, so FWIW............
4x4Wire's Toyota Section
1995 FZJ80 LandCruiser - 3 locking diffs, +200k mi, JD HIR's, 285/75R16 Nitto TG's
Olde North State Cruisers
Re: Axle Ratio [Re: little_joe] #548501 06/11/05 05:58 PM
Sith Offline
Must be that wheel change thing. I know in the TRD trucks at least when they went w/ 16" rims they went to 3.91 gears. I want to say I have seen the axle codes stamped on the door tag still but can't recall
Where does he get all those wonderful toys?
98 Tacoma SAS'ed marlined dented rolled ect ect
04 Rubicon.wrecked soon to be new playtoy
05 Titan current concrete commando
Re: Axle Ratio [Re: Sith] #548502 06/14/05 07:22 AM
taco99 Offline
02TRDexcab,gray wire mod,magnaflow,PIAA,dog smile
Re: Axle Ratio #548503 06/14/05 06:22 PM
Red_Chili Offline
Toyota Section Staffer
B06A=3.909
B06B=4.875
That cant be right, no offense. The # code designates the ratio, for 06 to be 2 different ratios would be incorrect.
Here's a more accurate list, also 4.30 is a lot more common than you may think, same goes for the 3.58.
These are the most common if not all of the ratios that appear in Tacoma Prerunners and 4x4's.
02 = 3.58
03 = 4.10
04 = 4.56
06 = 3.91
07 = 4.30
Sorry, I disagree: the dealer documentation is quite specific. The 06 by itself does not guarantee the ratio. The combination with the pinion (spider) count and the numeric code was very specific in the Toyota list, and came out to different ratios.
-Bill
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6085 MB (Peak: 0.6648 MB) Data Comp: Off Server Time: 2026-06-20 21:47:13 UTC
