Tire size #550676 01/11/05 07:35 AM
Gellekanao Offline OP
What is the biggest tire can a 2004 Montero accummodate without lifting it?? <img src="/forums/images/graemlins/cheers.gif" alt="" />
Exploring the outback is my game!
2005 Mitsu Gen3 Limited
OME Custom Suspension
Custom made safari roof rack
Garmin GPS
32X12.50X16 BFG Mud Terrain
1997 Mitsu Gen2 LS
Safari Roof rack
Garmin GPS
33x11.50x15 BFG MUds
Re: Tire size [Re: Gellekanao] #550677 01/12/05 06:58 AM
52degrees Offline
A temporary spare should go on pretty easily with a jack. Otherwise you will probably need a lift in order to get the tires off the ground. I prefer lifting to about chest level so I can hug the tire as I remove/install it.
<img src="/forums/images/graemlins/lol.gif" alt="" />
31x10.5
Clay
KG6VNX
Re: Tire size [Re: 52degrees] #550678 01/12/05 07:03 AM
What I meant was....What is the largest tire I can install on a 2004 Mitsu without changing the springs?
Garmin GPS
1997 Mitsu Gen2 LS
Safari Roof rack
Garmin GPS
Re: Tire size [Re: Gellekanao] #550679 01/12/05 07:18 AM
LOL, I'm sure Clay knows what you mean. He's just messing with you.
I think you'll find that this is mostly a wheeling site, and most folks aren't interested in wheeling such a new ride so we rarely get someone asking that question about such a new rig. That said, I do recall someone asking a similar question. Try doing a search for gen III or gen 3 and tire or wheel in the past year or two.
Also, I know that motorcare.com has done some tire fitting on the gen III montero's (pajero's elsewhere in the world). You may want to check their site at www.motorcare.com.au and here's a link to a gen III write-up they did... <click here>
There are a few on here with gen III's and I'm sure they'll chime in once they see your post. <img src="/forums/images/graemlins/kewl.gif" alt="" />
HTH
Re: Tire size [Re: off-roader] #550680 01/12/05 07:59 AM
52degrees Offline
Actually I couldn't stand to see your post drop off onto the next page. I figured if I said something silly it would not only get your post back to the top but might also shame someone who knows into giving you some kind of intelligent answer.
I'm sure 31x10.5 tires will fit. I don't know if you can fit larger ones, but i've seen those around here.
Clay
KG6VNX
Re: Tire size [Re: 52degrees] #550681 01/12/05 10:11 PM
OKRED Offline
Put 35's on there and hack away.
A brand spankin new 1973 series 3 Landy
OLIVE DRAB SWB, TURBO, IN ABOUT 36 PIECES
89 TROOPER, RESCUED FROM THE YARDS. (Down again)
05 TACOMA CREW SHORTY.
Re: Tire size [Re: OKRED] #550682 01/12/05 11:33 PM
OKRED Offline
Oh yeah maybe not on a brand new truck sorry. <img src="/forums/images/graemlins/shiner.gif" alt="" />
PHP: 7.4.33 Page Time: 0.010s Queries: 15 (0.007s) Memory: 0.6156 MB (Peak: 0.7100 MB) Data Comp: Off Server Time: 2026-11-16 08:53:41 UTC
