Page 3 of 3 1 2 3
Re: 2.8 TBI Upgrade, Holley or 4.3? [Re: JTW] #550809 11/07/07 03:45 PM
JTW Offline
Wow, what a difference. The first second I got it back on the street it was like driving a different vehicle. On the down side it seems to idle high but after about 10min of driving the idle goes back to a more normal state, around 1000 rpm. Anyone know what I could do to fix this? I think it might be the tps but I'm not sure, I'll fart around with it a bit this weekend. I know I'm going to be getting much worse gas milage because I let it get to 4000 rpm a little more often! Also with my old TB when I would really want to excelerate often the engine would surge, I was thinking this was an ignition problem and I was going to work on that next. I guess the injectors must have been dirty because the surge is gone and it's all go go go now. Great mod, as of right now I would saw it's way worth it. Picked up my Holley on ebay for a great deal.
Re: 2.8 TBI Upgrade, Holley or 4.3? [Re: JTW] #550810 11/08/07 03:09 AM
Ed Mc Offline
With a GM-type TBI system, anytime you make significant changes to engine airflow, whether it's intake or exhaust, you need to readjust the minimum idle air/speed settings & T.P.S voltage.
See this recent post for more info on the topic:
http://www.4x4wire.com/forums/showf...mp;amp;sb=5&o=14&fpart=1
Cheers..........ed
'90 Troop 3.4 LS
'89 Troop RS (Has Valve Issues, needs Counseling)
HI, I'm Ed and I'm a Trooper-holic!
Keep On Troopin'......
Re: 2.8 TBI Upgrade, Holley or 4.3? [Re: Ed Mc] #550811 11/09/07 08:17 PM
JTW Offline
It's running better than ever, just idles high for about the first 10 minutes then settles into a more normal idle range. I will be taking a look at the TPS voltage and see what that's like. Thanks for the help. Highly suggest that anyone with a 2.8 try this or the 4.3 throttle body, well worth the couple hours to install.
Page 3 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.009s) Memory: 0.6004 MB (Peak: 0.6552 MB) Data Comp: Off Server Time: 2026-07-14 08:16:50 UTC
