Re: starting problems....... [Re: hunterdan] #551254 01/12/05 10:36 PM
O
OffRodEO Offline OP
Lets see where shall i start...
I think its two things
1. contacts on starter
2. battery cables
let me explain why.
1. a long time ago, it did the click click start thingy, then that went away.
2. i blew some fuses couldnt figure out why, took it to the stealership they said battery cables, replaced fuses, things are ok
Heres the wierd thing. When i get up in the morning, i start it it turns over like 3 times, then dies, out of juice, click click click. Ok now the weird part, the second i put jumper cables on, it doesnt need ANY time to charge. It starts up with full power on the starter.
I have cleaned the terminals, but only a half <img src="/forums/images/graemlins/butwiggle.gif" alt="" /> job.
So today, now that i have time i will test all wires and see how much juice the battery is really pushing.
the alternator was replaced a year and a half ago, but it is a reman.
kevan
thanx guys
93 rodeo,3.2 manual, limo tint, nice sound system,keyless entry and a killer alarm, drop in K&N, 3 inch DOR lift, 32-11.50 BFG MT's, warn hubs zutah.com wheeler
WELLS FARGO BANK WILL RIP YOU OFF!GET OUT WHILE YOU CAN
Re: starting problems....... [Re: OffRodEO] #551255 01/13/05 03:18 AM
94rodeo Offline
Thanx troy, ill try that tommarow since the amigo wont be home till 10 pm
BTW, are you going on the pony express trail in FEB?
kevan
I will not know until i get a job and what not.
94 Rodeo
sas'd front dana 44(coil sprung), dual transfer cases (isuzu), tera lows, custom bumpers, winch, arb lockers[url= [url=http://community.webshots.com/user/94rodeo] [url=http://community.webshots.com/user/94rodeo[/url]http://community.webshots.com/user/94rodeo[/url]
Re: starting problems....... [Re: 94rodeo] #551256 01/13/05 04:21 PM
O
OffRodEO Offline OP
well guys thanx for the help, it was the battery cable, its all tore up. I half <img src="/forums/images/graemlins/butwiggle.gif" alt="" /> a better connection until i get paid to get a new one. thanx <img src="/forums/images/graemlins/kewl.gif" alt="" />
kevan
Re: starting problems....... [Re: Bigpoppax2] #551257 01/28/05 08:35 PM
i am about to dig into this same-sounding situation. i can only get the vehicle (88 trooper II) to start when i 'fred flintstone' it up to speed and pop the clutch and then crank it. whabamm it runs good. otherwise the ignition just grinds. same piggybacked solenoid on the starter and right now i am going by the Haynes book. once i remove the starter, how can i test it or the solenoid? advice? gracias.
mpH
Re: starting problems....... #551258 01/28/05 08:38 PM
O
OffRodEO Offline OP
I dont know exactly how to check a solonoid, you can hook it up to the battery and see if it works. The thing i would look into is the contacts, they could get all gunked up.
kevan
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6132 MB (Peak: 0.6745 MB) Data Comp: Off Server Time: 2026-06-07 11:29:10 UTC
