Page 4 of 5 1 2 3 4 5
Re: Suggestions for building an off road trailer... [Re: ForcedAir_Montero] #552210 02/09/05 11:37 PM
off-roader Offline OP
I've built several trailers with torsion axles, and love them. They are just too easy. I know they also are available as stubs. Just mount one to each side. I don't know what wieghts they are avail in for that configuration, but it'd great for ground clearance. Otherwise, just add a beefy skid plate to slide over anything.
They've got those at that site as well. Cost for a trailer axle kit would be $489 (3500lb's kit which is the only one that can use a 6x5.5 bolt pattern wheels).
Re: Suggestions for building an off road trailer... [Re: off-roader] #552211 02/10/05 02:39 AM
azrain Offline
I think that I'll just reuse the old springs on the chassis I find. They should be 1/2 ton and fairly long as opposed to normal trailer springs. Nice and flexible for off road but I think I'll need to add shocks or a sway bar for highway use. I know someone with 63" chebby springs on his trailer, I'll ask him and report back. That torsion axle is intriguing though...
I figure that I'll use a cantilever closing lid, split down the center with a "shelf" system below it to carry a piece of 1" plywood to pull up and make a tent floor. A small propane tank and a water tank need to be installed on this bad boy as well along with a shower / wash station on the outside. Over the fender tool boxes might be neat as well.
What would the ideal size be for a midsize SUV? I'm thinking something like 5' wide X 7' long on 33's with an articulating ball mount.
Mike
Re: Suggestions for building an off road trailer... [Re: azrain] #552212 02/10/05 03:03 AM
bretwalda Offline
Alot of the Aussie off road campers use a suspension along these lines - with a spring and shock for more travel:featherRide
concreteprinter.com
Re: Suggestions for building an off road trailer... [Re: bretwalda] #552213 02/10/05 03:51 AM
RockJock Offline
I once had a truck bed redneck trailer with stock springs. I only mention this because when I got it the thing didn't have shocks. I always thought it didn't pull well but then my Dad added some shocks to it and that dramaticly improved its handling. Leaf trailers with shocks rock, but i don't think that would be best for an offroad trailer.
Cheers,
RJ
Re: Suggestions for building an off road trailer... [Re: bretwalda] #552214 02/10/05 04:18 PM
LOL, did you see what they cost? <img src="/forums/images/graemlins/zombie.gif" alt="" /> <img src="/forums/images/graemlins/zombie.gif" alt="" /> <img src="/forums/images/graemlins/zombie.gif" alt="" /> <img src="/forums/images/graemlins/zombie.gif" alt="" />
Re: Suggestions for building an off road trailer... [Re: off-roader] #552215 02/11/05 07:32 PM
ForcedAir_Montero Offline
<img src="/forums/images/graemlins/scared.gif" alt="" /> <img src="/forums/images/graemlins/scared.gif" alt="" /> The last axle I bought was a custom 3500 lb'r and it only cost me $175! That was about four years ago, but still, that's a huge difference in price. I built a really nice pickup bed trailer for a demo for my bedliner business. The axle had to be a custom width, spindle drop, spindle angle, etc, dealie to fit in the fenderwells of the truck bed. It came out looking sweet. Looked like it had a 4" lift on it! I got lots of comments on that trailer, and many offers to buy it.
As for bolt pattern, you could easily get away with the adapters for a trailer <img src="/forums/images/graemlins/kewl.gif" alt="" /> I like the idea of starting with a V6 gen 1 monty frame though!
-Dave D
Reservoir of Useless Knowledge
"But... If I kill all the golfers, they'll lock me up, and throw away the key..."
-Bill Murray
'84&change Monty MPI Turbo, choptop, f&r lsd, swapped in AT- All the goodies!
Re: Suggestions for building an off road trailer... [Re: ForcedAir_Montero] #552216 02/12/05 09:06 AM
:8 <img src="/forums/images/graemlins/scared.gif" alt="" /> The last axle I bought was a custom 3500 lb'r and it only cost me $175! That was about four years ago, but still, that's a huge difference in price. I built a really nice pickup bed trailer for a demo for my bedliner business. The axle had to be a custom width, spindle drop, spindle angle, etc, dealie to fit in the fenderwells of the truck bed. It came out looking sweet. Looked like it had a 4" lift on it! I got lots of comments on that trailer, and many offers to buy it.
Here are the 1/2 torsion axles I was thinking of...
However if they make a 5 bolt to 6 bolt adapter plate, then I'll got with a lighter torsion axle (2k lbs vs 3.5k lbs) which will be alot less expensive overall per axle unless the adapter is $100 or more which would make the savings negligable.
Re: Suggestions for building an off road trailer... [Re: off-roader] #552217 02/16/05 06:00 AM
azrain Offline
Shoot, still looking for a frame or back half. Looked at a Nissan rear frame half, the yard wanted $500.00 for it, too rich for this project.
Also, talked to a local trailer manufacturer / dealer and they can get a 5200 lb tube axle with surge (hydraulic) brakes for $200.00 in various widths. Pretty fair break from the etrailer price.
Mike
Re: Suggestions for building an off road trailer... [Re: azrain] #552218 02/16/05 03:24 PM
Glad you brought that up. I was gonna check locally first as well before building/ordering anything.
TIA,
Ray <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Suggestions for building an off road trailer... [Re: off-roader] #552219 02/18/05 09:45 AM
Detail plans for Trailer Frame & idea for Trailer shell/enclosure.
[Linked Image][Linked Image]
Moderated by  4x4Wire, PHIL_
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6481 MB (Peak: 0.7615 MB) Data Comp: Off Server Time: 2026-06-07 07:17:00 UTC
