How do I remove a rusted 2" trailer receiver? #552417 01/14/05 11:35 PM
ScottFW Offline OP
So the 2" square tube hitch is rusted into the bumper's receiver, pretty well frozen. I managed to get the hitch pin out with a little hammering. The back side of the receiver is open, so I have access to that side as well.
I've been soaking it with rust penetrating lube for a few days...
This is what it looks like from the back side...
I've tried hitting it with a hammer (regular hammer, not a sledge type BFH) & brass punch from the back side but it's not budging. What to do? Just keep soaking with the rust lube and hammering till it pops out? I was thinking an air chisel might help but I don't have one of those. <img src="/forums/images/graemlins/confused.gif" alt="" /> Whatchyall think?
'85 4Runner (mostly stock) <img src="/forums/images/graemlins/kewl.gif" alt="" /> | '94 Miata <img src="/forums/images/graemlins/smile.gif" alt="" /> | '98 Saturn SC2 <img src="/forums/images/graemlins/rolleyes.gif" alt="" /> | '12 Ford Fusion (wife's company car)
Re: How do I remove a rusted 2" trailer receiver? [Re: ScottFW] #552418 01/14/05 11:39 PM
4
4xGeek Offline
Tried a torch? Heating along different points could cause it to shift around a smidge & break itself loose. But watch out, most penetrating fluids are highly flammable! <img src="/forums/images/graemlins/cheers.gif" alt="" />
4xGeek (Chris)
'97 T-100 4wd sr5-suto, 3" BL, 1.5" BJ spacers, 35" ProComp AT's, 4.88's, Bilsteins x 6, etc...
No longer stuck in SoCal!! smile
Re: How do I remove a rusted 2" trailer receiver? [Re: ScottFW] #552419 01/14/05 11:41 PM
John Smith Offline
Either get another chunk of receiver stock and a bigger BFH than you have and beat it from the back side to force it out or hitch up to a heavy immobile object, get the revs up to about 3k and dump the clutch. <img src="/forums/images/graemlins/lol.gif" alt="" />
I would personally go with plan A. If you decide on plan B please let us know if it worked or what broke. In the future it is a good idea to put some grease on the receiver so this does not happen in the future. <img src="/forums/images/graemlins/cyclops.gif" alt="" />
John Smith 79 FJ40
87 StdCab w/22R TLCA# 9074
Re: How do I remove a rusted 2" trailer receiver? [Re: John Smith] #552420 01/14/05 11:52 PM
If you go with plan B, plz have someone video tape it.
Re: How do I remove a rusted 2" trailer receiver? #552421 01/14/05 11:54 PM
4
4xGeek Offline
I've personally always done plan B, but I've never had one rusted in there like that! I wonder what would give 1st? <img src="/forums/images/graemlins/ignore.gif" alt="" />
4xGeek (Chris)
Re: How do I remove a rusted 2" trailer receiver? [Re: 4xGeek] #552422 01/15/05 12:26 AM
MnMsToY Offline
I would back up to a light pole or any other thing that isn't going to move. Put a chain on the ball and pole...put it in gear and go. Should come out really easy...or maybe ease your way forward...should come out. That is what I would do.
1980 Toy, Dovetail, Chevy 60/14, 5.13 gears "Wheeling isn't cheap anymore"
http://www.texas4x4.org/gallery/MikesToyota
Re: How do I remove a rusted 2" trailer receiver? [Re: John Smith] #552423 01/15/05 12:27 AM
ScottFW Offline OP
Yeah I already though of that, but then I thought better of it! <img src="/forums/images/graemlins/lol.gif" alt="" /> That's part of a Smittybilt bumper that is fairly well anchored to the frame, so the potential for catastrophically tweaking things is a little to high for my liking.
I'll probably try heating & beating. <img src="/forums/images/graemlins/ignore.gif" alt="" /> Propane torch (with a fire extinguisher nearby <img src="/forums/images/graemlins/notooth.gif" alt="" />), and a bigger FH. Where would one purchase a hunk of bare receiver stock?
I also though of putting my post Thanksgiving Harbor Freight specials to work (the $9 angle grinder and $15 sawzall) but I'd like it to come out intact if possible.
Keep those suggestions coming...
Re: How do I remove a rusted 2" trailer receiver? [Re: ScottFW] #552424 01/15/05 12:49 AM
OOP'S Offline
What kind of Penetrating oil are you using? Get some PB Blaster or Koil if you can. <img src="/forums/images/graemlins/smile.gif" alt="" />
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
Re: How do I remove a rusted 2" trailer receiver? [Re: ScottFW] #552425 01/15/05 12:53 AM
Marc M Offline
I had the same issue with the same bumper. I had to beat on the draw-bar for 45 minutes with a 10lb sledge to get that sucker out.
Have fun
Marc M
'06 Tacoma Dbl-cab, 4X4, V6, 6-spd, SR5/TRD....
'90 4Runner 4X4 SR5 5-Spd
'86 Shortbed 4X4 5-Spd, SAS'd ASAP
'82 Supra 5-Spd
Take your automatic and "Stick" it........
My Web Album in Progress
Re: How do I remove a rusted 2" trailer receiver? [Re: Marc M] #552426 01/15/05 01:04 AM
Heat the outside with a torch or heat gun and spray PB Blaster while doing that(rules out the torch). As the outside expands the heat will pull the PB Blaster on up into the gap. I used this method to separate a turbo housing from the center section. It took time, but it worked. I've also used this method to separate exhaust pipes.
PHP: 7.4.33 Page Time: 0.014s Queries: 16 (0.009s) Memory: 0.6395 MB (Peak: 0.7638 MB) Data Comp: Off Server Time: 2026-11-15 08:36:45 UTC
