need help with starter problem- electrical problem #553112 01/16/05 05:34 PM
Sid's Toy Offline OP
I had to jump start the vehicle after not driving it for 2 1/2 months. Its started fine. I knew it needed a cat so I drove it into the shop. When I dropped it off, it wouldn't start again. It doesn't click or try to crank.
I done a search and I think its somewhere between the relay and the starter, or may be the ignition switch.
My question is where do testing. My stepdad has a voltmeter but I'm not good with electrical problems. Where do I put the leads of the voltmeter. Sorry for such basic questions. Any help will be appreciated.
oh yea, I checked all fuses allready and cleaned the battery terminals.
Sid
92 4Runner SR5 3.0 standard tranny
4.88 gears, rear elocked, OME coils, SAW Tbars, allpro rock sliders and rear bumper, custom made front, downey v6 headers ...
Re: need help with starter problem- electrical problem [Re: Sid's Toy] #553113 01/16/05 05:47 PM
4Crawler Offline
See my page below for some troubleshooting ideas:
http://www.4crawler.com/4x4/CheapTricks/Starter.shtml
Basically, you want to measure the voltage at the starter solenoid control wire terminal. That is that small wire hooked to the starter. If that voltage (to ground) is more than 0.5V less than the battery voltage, then look upstream from the starter for the cause of the problem; connections, wiring, relay, ignition switch, etc.
Re: need help with starter problem- electrical problem [Re: 4Crawler] #553114 01/17/05 02:39 AM
Smoke Offline
Sounds like you might want to start with checking the battery. It might be bad if you had to jump it off!! Check the voltage at the battery first!!
94 P/U Ex-Cab 3.0 Automatic 4X4
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.009s) Memory: 0.5942 MB (Peak: 0.6482 MB) Data Comp: Off Server Time: 2026-07-17 02:06:55 UTC
