Page 1 of 3 1 2 3
Spark Plugs #554248 01/18/05 08:30 PM
javven Offline OP
I'm looking at re-replacing the spark plugs (I just changed). Ever since putting them in my rig's smoking like a chimney. I've gapped and re-gapped them to no avail. They're -the cheapest- autolite plugs in existance that are 'appropriate' for this vehicle.
Any suggestions / recommendations? Thinking of Bosch Platinum 4+ but not sure.
Change your oil hot and often.
07 Taco V6 4WD 5-Auto
Re: Spark Plugs [Re: javven] #554249 01/18/05 08:36 PM
LRJ4x4 Offline
If your burning oil don't use Bosch Platinum 4+ they will gum up very fast. Just get the OEM NGK's they work great!
BTW changing plugs will not make your truck stop smoking....that's the ring or valve seals <img src="/forums/images/graemlins/lol.gif" alt="" />
Re: Spark Plugs [Re: LRJ4x4] #554250 01/18/05 08:51 PM
javven Offline OP
It wasn't smoking until I changed the plugs. It's acting like it's running too rich.
Re: Spark Plugs [Re: javven] #554251 01/18/05 09:23 PM
Yellowhammer Offline
Bosch Super are good plugs. The platinum plugs are okay if your rig is running well and you are willing to allow the plugs time to reach operating temps before drag racing the ricers. <img src="/forums/images/graemlins/wink.gif" alt="" /> I agree with Les, don't use the platinum plugs if you are having problems. they will just foul up.
1991 Montero LS 3.0 5-Spd LWB 31" Bridgestone Dueller ATs on stock rims, tan/tan interior/exterior
1986 Isuzu Trooper 2.3 5-spd - partially disassembled, tan interior/dark blue exterior
Re: Spark Plugs [Re: javven] #554252 01/18/05 09:41 PM
Monty Offline
I myself have used nothing buy NGK Vpowers. Plugs are not going to make a difference at all. You have bad valve seals and/or guides, or you have bad rings. It's just coincident that the somke started after you did your plugs.
1989 Raider V6/MT
2005 Jeep Liberty CRD Turbo Diesel
Re: Spark Plugs [Re: Monty] #554253 01/18/05 09:48 PM
powerRam50 Offline
NGK <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Spark Plugs [Re: javven] #554254 01/18/05 10:06 PM
javven Offline OP
Oops. Can overfilling cause this? Darn manuals. I wish they'd agree. One lists SIX QUARTS as the fill requirement.
Will drain a little tonight.
Re: Spark Plugs [Re: javven] #554255 01/18/05 11:17 PM
torquemonster Offline
I use the Denso spark plugs...not the Iridium plugs but just the equivelant to the NGK V-Powers and they are cheaper and MUCH better quality than the NGK. I have been running mine for 60,000 km (37,500miles) and the "V" groove is still there. a couple years ago I ran the NGK V-powers and the "V" groove was gone in 5000 km (3125 miles).
Re: Spark Plugs [Re: torquemonster] #554256 01/18/05 11:31 PM
javven Offline OP
Get me a part number?
Re: Spark Plugs [Re: Monty] #554257 01/18/05 11:45 PM
W
wyleone Offline
<img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" />
I run V-powers in everything i owned in the last 15years w/no problems. I change them every 20K mi, They don't wear that bad for me.
Specialized part number repository
The sparkplugs recommended for any of the mitsu motors are listed here w/discriptions. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Page 1 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.012s Queries: 16 (0.009s) Memory: 0.6361 MB (Peak: 0.7583 MB) Data Comp: Off Server Time: 2026-11-16 08:33:22 UTC
