87 Trooper II Engine Swap #555453 01/21/05 05:09 AM
I have a 1987 Isuzu Trooper II, with a rebuilt 4 cylinder 2.3L engine. I'm doing research to determine what engine I can swap with my current. I would like to swap my 2.3L a bigger engine with more horsepower and more torque. But I'm not sure what engines I can swap, with few or no major modifactions needed. I know that I can use a 4 cylinder 2.6L, but I wasn't sure if that would be a worth wild swap or not. I've also looked at the 89 6 cylinder 2.8L, but was unsure if they could be switched out. Thanks.
Re: 87 Trooper II Engine Swap #555454 01/21/05 05:44 AM
Do you have a Automatic Transmission by chance?
If so, and its a four speed (30-80le/AW4/A340H) there is a number of engines that can be swapped.
Re: 87 Trooper II Engine Swap #555455 01/21/05 05:45 AM
No, I have a five speed manual.
Re: 87 Trooper II Engine Swap #555456 01/21/05 06:27 AM
coldrain Offline
With a manual transmission the only engine that is direct bolt on from the 2.3L engine is the 2.6L engine. Now if you want to change transmission and build some custom motor mounts, just about any thing is possible. Of course though, it will $$$.
Re: 87 Trooper II Engine Swap #555457 01/23/05 07:32 AM
If I understand you correctly , the 2.3 auto has many swap options, could this be the same for the 2.6? I have an 89 automatic with a 2.6 , what are the options for swap outs for me?
Re: 87 Trooper II Engine Swap #555458 01/23/05 07:30 PM
http://www.4x4wire.com/forums/showf...&o=&fpart=1&vc=1
PHP: 7.4.33 Page Time: 0.010s Queries: 14 (0.008s) Memory: 0.5977 MB (Peak: 0.6659 MB) Data Comp: Off Server Time: 2026-07-15 13:52:06 UTC
