Re: Check those exhaust manifold studs!!! [Re: fasteddy] #556064 01/24/05 12:01 AM
OKRED Offline
That's a good idea FE, I wansn't even thinking that far.
A brand spankin new 1973 series 3 Landy
OLIVE DRAB SWB, TURBO, IN ABOUT 36 PIECES
89 TROOPER, RESCUED FROM THE YARDS. (Down again)
05 TACOMA CREW SHORTY.
Re: Check those exhaust manifold studs!!! [Re: cragdweller] #556065 01/24/05 08:47 AM
L
lu0902 Offline
Damn! Now I am concern. As soon as I am done with my front brakes, I will be checking the studs on my truck. I might have over tighten the nuts. <img src="/forums/images/graemlins/scared.gif" alt="" />
1987 DODGE RAIDER 4X4, 2.6 LITTER, 5 SPEED MANUAL MODS+PARTS:
Re: Check those exhaust manifold studs!!! [Re: lu0902] #556066 01/24/05 04:29 PM
There's nothing worse than overtightening your nuts!! <img src="/forums/images/graemlins/lol.gif" alt="" />
Cheers.
Re: Check those exhaust manifold studs!!! [Re: cragdweller] #556067 01/24/05 07:57 PM
torquemonster Offline
Unfortunately, my luck seems to always leave me with a stud broken off flush with the gasket surface or even below it. The weld trick won't work on those.
Oh yes they will...you just gotta feed the mig wire throught the middle of the nut onto the broken stud...Thats mainly what I fix is studs that are broken as far as 1/4 inch into the head. I can still make contact with it and I can always get it out.
Re: Check those exhaust manifold studs!!! [Re: torquemonster] #556068 01/25/05 05:55 AM
highmtndesert Offline
And this is called what.
Now the question is will a heli-coil fix this or do I pull the head off and try something else?
Well on my way to becoming that eccentric old man in every town.(crazy as a s#@thouse rat) With a yard full of desireable old vehicles that tells you, Sorry they're not for sale..... Someday I'm going to fix them.
Re: Check those exhaust manifold studs!!! [Re: highmtndesert] #556069 01/25/05 07:17 AM
Vic Lee Offline
A heli-coil should work, but if the hole is already too large for the heli-coil, a Keen-Sert would work. It uses
a larger hole and thread for the insert install. Keen-Serts
can also be purchased solid, without a threaded thru hole so that you can drill and tap your own for a special size or offset location etc.
1990 Montero 2dr 3.0 Auto Lsd Front & Rear
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6153 MB (Peak: 0.6851 MB) Data Comp: Off Server Time: 2026-06-20 17:31:47 UTC
