Winch Rating
#557460
01/25/05 06:30 AM
I have a Warn Trans4mer brush guard winch setup. A friend of mine has a 12,000 lb warn winch that he is wanting to get rid of. My plate says it can take up to a 9,000 lb winch, why only that much? Will his winch fit on my plate. Why will this or won't this work? Thanks for any info on this subject. -Sam
Re: Winch Rating
#557461
02/06/05 10:08 PM
Im new to tacos, but I would assume its 9k for one or both of these reasons:
1) The mounting point (transformer mount) is only rated at 9k due to the build, and design, its just not rated for a 12k pull
2) the 12k warn is a larger winch in itself and wont fit in
Nate Johnson 1993 Isuzu Rodeo 4wd - Not Much Crap 1998 Chevy Silverado 2500 - A little More Crap 2006 Suzuki Z400 - A Bit More Than A Little More Crap 2004 Yamaha Raptor 660 - Lots of Crap
Re: Winch Rating
[Re: NJ_dup1]
#557462
02/08/05 06:29 PM
I figured thats what it meant but I wanted to make sure it wasn't just a recomendation. Like the speed your recomended to go around a corner at or the size tire your supposed to use... Heck with recomendations <img src="/forums/images/graemlins/evil.gif" alt="" />
Re: Winch Rating
#557463
02/08/05 08:44 PM
Toyota Section Staffer
Yeah, heck with recommendations... but it will pull that winch mount clean off your truck, man. POINK! <img src="/forums/images/graemlins/oink.gif" alt="" />
-Bill '87 4Runner w/ '96 5VZ-FE, 'Red Chili II' '97 Taco XtraCab 3RZ-FE, 'BlackBean' TLCA # 13257, Rising Sun 4x4 Club Land Use Coordinator "He who stops being better stops being good." -Oliver Cromwell
Re: Winch Rating
[Re: Red_Chili]
#557464
02/08/05 10:55 PM
Turns out he thinks that winch is made of solid gold or something.... Sounds like its for the best though. Oh well <img src="/forums/images/graemlins/shiner.gif" alt="" />
Re: Winch Rating
#557465
02/09/05 04:59 PM
You might look at the Warn Magnum line if you are on a budget. Chinese, but they look not to be too bad.
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6017 MB (Peak: 0.6691 MB) Data Comp: Off Server Time: 2026-07-09 17:53:52 UTCValid HTML 5 and Valid CSS
