starting the SOA project ..need rear driveshaft advice
#557906
01/26/05 12:01 AM
Ok I really don't want to drop 300 for a Tom Woods C/V style rear shaft
My question is what are my alternatives... this is a trail rig that will be SOA front with 1/4 eliptic rear moved back about 8" (YJ)
Re: starting the SOA project ..need rear driveshaft advice
[Re: TX4wl]
#557907
01/26/05 12:24 AM
Dallas spend the bucks! Find out eggszackly what you need and spend the bucks! Big Jim <img src="/forums/images/graemlins/pfft.gif" alt="" />
[Re: BigJim]
#557908
01/26/05 12:32 AM
I have been told and have seen people use an XJ front shaft and have a drivline shop fix it up.. just wanted soem thoughts from you guys..it seems to work well but then again why does tom woods charge an arm and a leg for his??.... just want to do it correctly but sometimes researching what others have done saves alotta $$ <img src="/forums/images/graemlins/nana.gif" alt="" />
[Re: TX4wl]
#557909
01/26/05 12:36 AM
There's absolutely nothing wrong with having a driveshaft shop cut down an already existing shaft to the dimensions you need. I would suggest a front shaft from any pre-2003 (or whatever year they went to independent rear suspension) Ford Explorer. They have a fairly large diameter, thick wall tube and a CV joint at the transfer case end. You'll need the proper Torx bit to remove it at the junkyard.
I use these on my CJ's and cut them down myself.
Tom's prices aren't any higher than anyone else's for a new shaft. They are all new parts and the DOM tubing used is not cheap.
#557910
01/26/05 12:50 AM
Tom's prices aren't any higher than anyone else's for a new shaft. They are all new parts and the DOM tubing used is not cheap. how much do these run in the yard ... and have you seen this set up on a YJ ...one more thing to consider the rear will be moved back about 6-8" <img src="/forums/images/graemlins/nana.gif" alt="" />
[Re: TX4wl]
#557911
01/26/05 01:58 AM
i too have heard of the use of a XJ front shaft cut to length. it sounds very doable, and i have had a driveline shortened by my local shop for 40$. if you can find a good shaft i think a 40$ experiment offsets the cost of a 300$ shaft.
#557912
01/26/05 03:33 AM
I hope those XJ front shafts are better than a YJ's
RockJock <img src="/forums/images/graemlins/cheers.gif" alt="" />
[Re: RockJock]
#557913
01/26/05 05:43 AM
the early XJ shafts are flimsy straws, along the same lines as the YJ's. the latter XJ shafts were upgraded to a much more robust design in the early-mid 90's, when they front axle when from disconnect to non disconnet. i have one laying in the back yard if you would like a picture.
#557914
01/26/05 05:44 AM
please show me a pic <img src="/forums/images/graemlins/nana.gif" alt="" />
[Re: TX4wl]
#557915
01/26/05 06:01 AM
here you go. if you look you can see the factory balancing weight by the CV joint. ![[Linked Image]](http://mysite.verizon.net/res85ht0/XJfront.JPG)
PHP: 7.4.33 Page Time: 3.625s Queries: 16 (0.004s) Memory: 0.6281 MB (Peak: 0.7349 MB) Data Comp: Off Server Time: 2026-06-20 21:39:05 UTCValid HTML 5 and Valid CSS
